Float calculation from sensor event data?
I am interfacing some sensors on Arduino uno. I encountered a problem with a LPS25 pressure sensor.
When i use the test code below, I can see the temperature and pressure reading in the serial monitor but when I include the two floating variable (Operator and result), the code don't want to compile and return the following error:
" no match for 'operator*' (operand types are 'sensors_event_t' and 'float') "
How to use those data ? What is going on? I am new to this.
thank you
// Basic demo for pressure readings from Adafruit LPS2X
#include <Wire.h>
#include <Adafruit_LPS2X.h>
#include <Adafruit_Sensor.h>
// For SPI mode, we need a CS pin
#define LPS_CS 8
// For software-SPI mode we need SCK/MOSI/MISO pins
#define LPS_SCK 12
#define LPS_MISO 11
#define LPS_MOSI 9
Adafruit_LPS2X lps;
float Operator;     // The variable I put to try some math transformation
float result;       // The variable I put to try some math transformation
void setup(void) {
  Serial.begin(57600);
  while (!Serial) delay(10);
  Operator = 17.52;              // Random value for testing
  Serial.println("Adafruit LPS2X test!");
  // Try to initialize!
  //if (!lps.begin_I2C()) {
  //if (!lps.begin_SPI(LPS_CS)) {
  if (!lps.begin_SPI(LPS_CS, LPS_SCK, LPS_MISO, LPS_MOSI)) {
    Serial.println("Failed to find LPS2X chip");
    while (1) { delay(10); }
  Serial.println("LPS2X Found!");
  lps.setDataRate(LPS2X_RATE_1_HZ);
  sensors_event_t temp;
  sensors_event_t pressure;
  lps.getEvent(&pressure, &temp);
  result = temp * Operator / pressure;    // This is the line that return the error message
  Serial.print(temp);
  Serial.print(" ");
  Serial.print(pressure);
  Serial.print(" ");
  Serial.println(result);
sensors_event_t is a struct not a float type. You need to reference the field in the struct that you want.
Try this:
  sensors_event_t tempEvent;
  sensors_event_t pressureEvent;
  lps.getEvent(&pressureEvent, &tempEvent);
  result = tempEvent.temperature * Operator / pressureEvent.pressure;    // This is the line that return the error message
  Serial.print(tempEvent.temperature);
  Serial.print(" ");
  Serial.print(pressureEvent.pressure);
  Serial.print(" ");
This work but I don't understand why!
I guess I will have to read about Stuct.
and what is this : tempEvent.temperature
what is the " . " for?
thank you Todd
cdb101:
You answered your own question.
cdb101:
thank you Todd
You need to study up on structs and also look at the documentation for Adafruit_Sensor.h. It will tell you what all of the members of the structures are.
