float calculations
Hello, from a beginner :) :)
I am very new to Arduino and C programming, and trying to find my way through it. Slowly and by reading and trial and error I am learning, so please bear with me...
While I was trying to work with some floats, I noticed that a code such as
float var; var=3/4; Serial.println(var,4);
returns 0.0000
but if you do float var; var=(float) 3/4; Serial.println(var,4);
then it returns 0.7500 (as desired)
Can someone help me understand why is this, and is this (casting) the correct way to use floats?
Much appreciated;
Try var = 3/4.0; to force the calculation to be done as a float rather than integer which is the default.
For integer division, 3/4 is zero, with a remainder of 3.
Wow, that was fast!
thanks for the quick reply
So if I understand this correctly, default calculations happen as int type even though the destination variable is float.
good to know.
Wow, that was fast!
We aim to please !
Unless you tell it differently, the default math operations assume int data types. As Bob pointed out, using a decimal point on numeric constants tells the compiler to use floating point math. As you might guess, all of these forms produce the same result:
float var;
var = 3.0 / 4;
var = 3.0 / 4.0;
var = 3 /(float) 4;
var = (float) 3 / 4;
var = (float) 3 / (float) 4;
They work properly because all of them nudge the compiler in the right direction for the math operation.
