float division problem (x / y = inf)
Hi everyone, i’m working on a calculator project but i can’t understand how to make division work.
It’s probably caused by the usage of 2 float and factors and another float since when i write make a division between two set variable i get a correct result.
I will post the entire code in case it’s needed, but the function that gives me problems is “calcolo”.
I’m sorry if the comments are not in english, but i can explain the code if needed.
#include <LiquidCrystal.h>
#include <Keypad.h>
const byte ROWS = 4; //quattro righe
const byte COLS = 5; //cinque colonne
char keys[ROWS][COLS] = {
  {'1','2','3','+','-'},
  {'4','5','6','*','/'},
  {'7','8','9','R','E'},
  {'.','0','#','P','L'}
byte rowPins[ROWS] = {38, 36, 34, 32}; //dichiara i pin delle quattro righe della tastiera
byte colPins[COLS] = {30, 28, 26, 24, 22}; //dichiara i pin delle cinque colonne della tastiera
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); //inizializza la funzione keypad della tastiera
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); //dichiara i pin del display
float A = 0;
char OP;
float B = 0;
float TOT = 0;
void setup(){
    // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.clear();
void loop(){
  lcd.clear();
  delay(10);
  A = letturafattore();
  lcd.setCursor(8,0);
  OP = letturaop();
  lcd.setCursor(10,0);
  if (OP != 'L'){
    B = letturafattore();
  lcd.setCursor(0,1);
  TOT = calcolo (OP);
  Serial.print(TOT);
  attesa();
void attesa(){
  int conferma = 0;
  while (conferma == 0){
    char key = keypad.getKey();
    if (key == '#') conferma = 1;
float calcolo ( char op){    // FUNZIONE DEL CALCOLO
  float a = 1.00;
  float b = 2.00;
  float ris = 0;
  float esp = 0;
  Serial.println(a);
  Serial.println(b);
  switch (op){
    case '+':
      ris = a + b;
    case '-':
      ris = a - b;
    case '*':
      ris = a * b;
    case '/':
      if (b = 0){
        lcd.clear();
        lcd.setCursor (0,0);
        lcd.print ("DIVISIONE PER 0!");
        errloop();
      else {
        ris = a / b;
    case 'R':
      if (a < 0){
        lcd.clear();
        lcd.print ("RADICE NEGATIVA!");
        errloop();
      else if (b = 0){
        lcd.clear();
        lcd.print ("B UGUALE A 0!");
        errloop();
      else {
        ris = pow (a, 1/b);
    case 'E':
      ris = pow(a, b);
    case 'P':
      ris = (a / 100) * b;
    case 'L':
      if (a <= 0){
        lcd.clear();
        lcd.print ("A NON POSITIVO!");
        errloop();
      else{
        ris = log10(a);
  /*if(ris != check(ris)){
    lcd.clear();
    lcd.print ("TROPPO GRANDE!");
    errloop();
  Serial.print("Risultato = ");
  Serial.print(ris);
  if(ris > 9999999999999){
    lcd.clear();
    lcd.setCursor(0,0);
    errloop();
  return ris;
float check(float A){    // FUNZIONE DI CONTROLLO
  Serial.println (A);
  A = A*pow(10,-23);
  Serial.println (A);
  A = A*pow(10,23);
  Serial.println (A);
  return A;
float letturafattore (){    // FUNZIONE LETTURA FATTORI
  int conferma = 0;
  int dot = 0;
  int arr [6] = {0,11,11,11,11,11}; //vettore del primo numero
  bool pos = HIGH; //segno del primo numero
  float fattore = 0;
  for(int i = 0; i < 6 && conferma != 1; i++){                //INSERIMENTO DEL PRIMO FATTORE
    if(key == '#') conferma = 1;
    else if(key == '+' && i == 0) {   //assegna a pos il valore + controllando che sia in prima posizione
      pos = HIGH;
      arr[i] = 0;
      lcd.print("+");
    else if(key == '-' && i == 0){    //assegna a pos il valore - controllando che sia in prima posizione
      pos = LOW;
      arr[i] = 0;
      lcd.print("-");
    else if(key == '.' && dot == 0) {    //scrive il punto e segna la posizione con un 10. Impedisce che venga scritto due volte
      arr[i] = 10;
      dot = 1;
      lcd.print(".");
    else if(key == NO_KEY || key == '*' || key == '/' || key == 'R' || key == 'E' || key == 'P' || key == 'L' || key == '+' || key == '-' || key == '.') i=i-1;
    else{
      arr[i] = key - 48;
      lcd.print(arr[i]);
  Serial.print("FATTORE ACQUISITO = ");
  Serial.print(arr[0]);
  Serial.print(arr[1]);
  Serial.print(arr[2]);
  Serial.print(arr[3]);
  Serial.print(arr[4]);
  Serial.println(arr[5]);
  fattore = arrtoint (arr, pos);
  Serial.print("DOPO CONVERSIONE = ");
  Serial.println(fattore);
  return fattore;
char letturaop(){    // FUNZIONE LETTURA OPERAZIONE
  int conferma = 0;
  char op;
  while (conferma !=1){
    if (key == '#'){
      conferma = 1;
    else if (key == NO_KEY || key == '0' || key == '1' || key == '2' || key == '3' || key == '4' || key == '5' || key == '6' || key == '7' || key == '8' || key == '9' );
    else {
      lcd.setCursor(8,0);
      lcd.print(key);
      op = key;
  return op;
float arrtoint (int arr[6], bool pos){  //CONVERTE LA MATRICE IN UN NUMERO INTERO
  int x = 0;
  int x1 = 0;
  float result = 0;
  float dec = 0;
  int n = 0;
  int z = 1;
  for (int i = 0; i < 6 && arr[i] != 11; i++){
    if ( arr[i] < 0 || arr[i] > 10 ){
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("ERR NON DEFINITO");
      errloop();
    else if (arr[i] == 10){ //Controlla se nella posizione c'è il punto
      x = 1;
      x1 = 1;
    else if (x == 1 && x1 == 1){ //Converte la prima cifra dopo la virgola
      delay (10);
      result = result /10;
      x1 = 0;
      dec = arr[i];
      dec = dec / pow(10,z);
      result = result + dec;
      z++;
    else if (x == 1){ //Converte le successive cifre dopo la virgola
      delay (10);
      dec = arr[i];
      z++;
    else { //Converte le cifre prima della virgola
      delay (10);
      result = result + arr[i];
      result = result * 10;
  if (x == 0) result = result/10; //Corregge la conversione nel caso non ci sia la virgola
  if (pos == LOW) result = result * -1; //Assegna il segno negativo
  return result; //Restituisce il risultato della conversione
void errloop(){    //VA IN LOOP
  int a = 0;
  lcd.setCursor(0,1);
  lcd.print("RIAVVIARE");
  while(a == 0) delay (1000);
The main problem is that every number i assign from the other function to A and B the division between the two will be “inf”
That’s an example of the serial monitor when i run the program
FATTORE ACQUISITO = 11111111111
DOPO CONVERSIONE = 1.00
FATTORE ACQUISITO = 51111111111
DOPO CONVERSIONE = 5.00
1.00
2.00
Risultato = inf
I will be very glad to anyone who helps me, since that’s for an exam and it’s the only error i get :slight_smile:
= means set a variable to a value, == means test for equality. if (b = 0) is wrong.
vaj4088: = means set a variable to a value, == means test for equality. if (b = 0) is wrong.
unless you want to assign zero to 'b' and make absolutely sure that the outcome is false.
I can’t believe it was an error so stupid :facepalm:
I also checked the entire code for these little f*ckers before, maybe i added these after that…
Oh, and of course now it works.
Thank you so much :slight_smile:
indeed - what happens in this code
 if (b = 0){
        lcd.clear();
        errloop();
      else {
        ris = a / b;
is that you set b to 0
(b = 0) being an expression that returns the value being set, returns 0
the if is evaluating this as if (0) so execute the code in the else statement but because b was set to zero, you get a nice division by zero
nice bug. always hard to see those. great catch by vaj4088!
Unless you get the compiler to do the hard workif (0 = b) will give you a build-stopping error.
Put the constant first.
smart!
AWOL: Unless you get the compiler to do the hard workif (0 = b) will give you a build-stopping error.
Didn't know that Thanks for the tip :o
It's just a small hint; it doesn't work for variables, so if you wrote if (a=b), you're in the lap of the compiler.
