float error
I have code:
int nnn = 0;
float fff = 0.02;
fff = fff * 10.0;  //fff = 0.2;
fff = fff * 10.0;  //fff = 2.0;
nnn= fff;         //nnn = 2;
Serial.println(nnn);  //why? nnn =1;   ????
help me! Thanks!
That code does not compile, so can't print anything.
(nnn is.probably about 1.999)
  int nnn = 0;
  float fff = 0.02;
  Serial.println(fff, 7);
  nnn = fff;         //nnn = 2;
The output is
0.0200000
0.2000000
1.9999999
1
Arduino - Cast Casting Float to Int (Existing thread)
EDIT : Fixed cast link
Thanks for the reply! I found a solution.
int nnn = 0; float fff = 0.02;
fff = fff * 10.0; //fff = 0.2; fff= round(fff *10000.0)/10000.0; fff = fff * 10.0; //fff = 2.0; fff= round(fff *10000.0)/10000.0; nnn= fff; //nnn = 2;
Serial.println(nnn); //The output is: 2
I found a solution.
And then made it much more complicated than it needed to be.
  nnn = round(fff);
You only understand part of the problem.
vanlamtk: You only understand part of the problem.
You only asked part of the problem.
