Float print oddity
Working on another little project I found this incorrect output:
  float floatVar = 30.141;
  float newVar = 4.275;
  //    Serial.println(floatVar);
  Serial.println(newVar, 3);
UNO R3, IDE 1.8.10
The sketch above will not print newVar. If I remove the comment from the first floatVar print it won't print the first floatVar but the two following prints are executed.
What is going on?
The sketch above works fine for me. Either way.
I've noticed in quite a few of my sketches where I have something printing in setup shortly after begin that I don't see anything from the first print. Even with quoted constant strings. The first one won't print but the second one and all subsequent ones will.
Sometimes a short delay after begin seems to change things and sometimes not. I've just gotten into the habit of printing some garbage right after I call begin.
the behavior seems new because some of these codes used to run and print everything and now they miss the first line. I thought it might be my computer.
Loss of initial serial output frequently happens with the 32u4 processors, which take some time to connect with the USB virtual serial port.
Fix it with
while(!Serial); //after the Serial.init(baud);
jremington:
Fix it with
Mine is having problems on 1284P running MightyCore. It's on a Ubuntu 18.04 machine.
jremington:
Fix it with
That doesn't work for me. It's as if it's not even there.
Delta_G:
This is the only thing that works on its own:
//   while(!Serial);  // no effect
  Serial.println(""); // the cure
I also discovered that if the first print after download doesn't work it will if the processor reset button is subsequently pressed.
Thanks for the replies and suggestions. I hadn't seen this before but now I know how to get around it.
Karma++.
Also, prints fine for me in NANO + IDE 1.8.12.
That's not a cure. That's a workaround.
And the empty string in there looks stupid.
PaulS:
The pertinent part is 'works'.
PaulS:
Got anything constructive to add?
