Float to array?
I have a few seven segment leds and I want the temperature ic float displayed. The code is set up so an integer is assigned to each digit. (working test code) int a=1; int b=2; int c=3; write_digits(a,b,c);
Is there an easy way to have a float to array? Then my temperature ic could do something like: float temperature = getTemp(); somehow put the float into an array write_digits(temp[0],temp[1],temp[2],temp[3]);
dtostrf()
Although, since you know the precision you want, you could just multiply it by 10^n, where n is how many digits you want, assign it to an int, and send it through atoi().
Typically done with divisions:
  c=temperature % 10;  temperature / = 10;
  b=temperature % 10;  temperature / = 10;
  a=temperature % 10;
For that to be fast and accurate, you want temperature to be an integer.
So here is the irony of your proposal: you want to convert an integer into float, only to have to convert it back to integer so you can do what you are trying to do.
dhenry is 100% right, integer math is much faster. however the last - % -modulo - is not needed ;)
int t = (int)temperature;
c= t % 10;  t /= 10;
b=t % 10;   t /= 10;
a=t;  // assume temp = 0..999
It works! Thanks to all for the help. I’m trying to figure it now since I stick to hardware design and rarely write code. I have no idea what the line t /= 10; is yet but i’ll figure it out. I think I have the rest of it in my head.
Mike
0miker0: I have no idea what the line t /= 10; is yet but i'll figure it out. I think I have the rest of it in my head.
Mike
It's shorthand for writing out the full assignment statement:
t = t / 10.
In English, it says take the variable t, divide it by 10 and store it back in t.
