I have a problem with converting some float result to char.
For example converting 1.05 to char, become 1.5.
The code for the converting prosess:
char* FtoChar2(float fVal, char* cF) {
// Force number of decimal places to full 2
int iDigs = 2;
// Separator = 10 ˆ Number of decimal places
long dSep = pow(10, iDigs);
// Display value = floal value * separator
signed long slVal = fVal * dSep;
sprintf(cF, "%d.%d", int(slVal / dSep), int(slVal % int(dSep)));
FtoChar2(battV, cbattV); // this is the exampe, battV is 13.08, but the cbattV result become 13.8
2. You want ASCII codes for '1', '3', '.', '0', and '8'. That means there will be 5 elements in the output string. The ASCII codes for the elements are: 0x31, 0x33, 0x2E, 0x30, and 0x38.
3. The following C-function could be used to get the ASCII codes of the given float number.
dtostrf(arg1, arg2, arg3, arg4);
Where:
arg1 = float value = 13.08
arg2 = Number of ASCII codes in the output string = 5 (called field width)
arg3 = Number of digits after decimal point = 2 (called precision)
arg4 = Null terminated array to hold output string. (char myArray[10] = "";)
==> dtostrf(y, 5, 2, myBuffer);
