float to hex?
Probably stupid, but i calculate some float value with a result 0.0 to 255.0 . I have to set a timer counter value at :
  REG_TC4_COUNT8_CC0 = 0x55; //or other value
How would I convert
float CC=137.0
into a hex value (to replace the 0x55 in the timer counter as other possible value) ?
Thanks.
byte myVar = CC;
But why did you use a float in the first place then?
Btw, it's not a conversion to hex (which is only a representation of a number) but a conversion to integer.
Not sure if this is what you want, but all numbers are ultimately stored in binary, so picking one over another is just its representation:
  float CC = 137.0;
  int val;
  val = (int) CC;
  Serial.print("val = ");
  Serial.println(val, HEX);
