Float to Int conversion problem
I am trying to use a slider potentiometer to control the master volume on my PC. I have the AutoIt program written and it needs the volume in a percentage. I am trying to convert the value from the slider pot to a percentage using the formula of (value/maxvalue)*100. I am doing the calculation in a float and then converting it to a int and sending it over serial. Please help me figure this out.
-Tim
The code marked
///HERE///
is the calculation.
Here is my code:
*  SerialVolumeSlider
*  Reads an analog input from the input pin and sends the value
*  as a percentage followed by a line break over the serial port.
// variables for input pin and control LED
  int analogInput = 4;
  int LEDpin = 13;
  int incomingByte = 0;      // for incoming serial data
  int maxValue = 1023;
// variable to store the value
  float fvalue = 0.00;
  int value = 0;
// a threshold to decide when the LED turns on
  int threshold = 512;
void setup(){
// declaration of pin modes
  pinMode(analogInput, INPUT);
  pinMode(LEDpin, OUTPUT);
// begin sending over serial port
  beginSerial(9600);
  Serial.println("Ready.");
void loop(){
// read the value on analog input
  value = analogRead(analogInput);
// if value greater than threshold turn on LED
if (value < threshold) digitalWrite(LEDpin, HIGH); else digitalWrite(LEDpin, LOW);
///HERE///
fvalue = (value/maxValue)*100;
value = (int)(fvalue);
if (getping() == 1) {
  Serial.println(value);
  delay(10);
//  printInteger(value);
int getping(){
  incomingByte = Serial.read();
  if (incomingByte == 80) {
    //Serial.println(incomingByte);
    return 1;
  else {
    return 0;
Now when I plug in my Arduino, without doing anything to it, using the Serial Monitor in Arduino it gives me this:
Ready.
9188908891908289968989908184899090899189899190908491909090898398919091878191889190908090889090908590899088919090909190898591919188908990898988889089889191878990899090838994929089899488909092839191908992868989909091839890889091908890908992918991889190909489909089898890909091908889908890939092898984929792899184919089909189869189909189968888889090901009090828789898990929089898889869189909188899990898890829094899293928491909091899492929090889790899186889690918988828790898989898991898989849192888993868990928991959290908982909689929190838992909192919090899291889491898592888890899080859290898889909189909089939289919187968989898883898890899089898992908986918989889389889090898185908890928890928988898288958990908890919090918996939089908989909288908994909090908990909089908888899289899088889088919096918889908489898993919396908992928789918990909291899190829189918990918990929092909296899185919789888888898897909188849390899089849190899089869490899183899590909191929090889081889690909090889088929290879292889090888991889183909690918886918989899290929090899091908890908989989089898890938892909085908990908886888990888890969090908681908989929091888889908886908992939090978990898189998887919090909088919093979090909098909090879093909089919089909190868894889190918392898889869090898890929288889089848894909089888289888991818988919190909288908989849088898891899690918889899291889191908788889092889691899192919188908891868990909090848989899191918988908983899090928990919289888890908992898882899490899180849090899089909090899092909988918989899090908982899090889090899090909188929089899081928991909192979091889190899089929292988891918789919090898189929088898989908990899092909190928993918888909097908990878890889190918998928991909089929289909090889089918592909190919297928988838990888989919090908991928589908990899691908890809098908990899089908991909198898889908990908984889393899190909090909288889589898891828989908990901009090898290909092918191909088909096909091918288899290899095909091929192898890828998909189899088919089899288889089859090918889859690919091909289909086899489909090818989908988929090908991928990918988889689919089829190909091919389918992879191909192908888909080928989899084888989888983889190908990889290918882899389919189899090918985929090899284889090908089998988909189889191889091969289909186909188908190958989899084889292899093909089908189999091909196889192898389898889909091908892879193888991908993899388889296899090918990888891909098899089919289898894878894899089899191909089918991898892899389898991849292899190879991898889839091919191919090928893869090928890928888898982899788899088909288899090919889909089879189909192959290889089858890909091948889889082899689889292978990909089919588909089979188908783909090929091909090909089909291898891908892928992899089919188899088929091909190909088908889898589899290898695929292908494908990918990909090899089919089889092908888908895909091908989899190908999909088888390899191929390909089808890909091909189909190881019090918888929089889289929089918690909291919090909088938990899290899096889188899087919090909096899089898490899291908896908891908590899190909088899089849296919089929888889190808592889189908990888990938899909289858289909091909888899091898988909390929790909190808990908989898990889092889091919083909689888888899191909190909189919288899390898990919091908888889088919186909088908989938889919186979288889083898990908992908989919183929090899190908989898090908888919082899190898990988991909090929090928288988890898995898891919093989189918886919090899089928990889089899089909291918889908288929089908892908889898989889088929199909089869197888889909293928991898993889190919090899090829388889091879988908988929090899191869790888983859288908989859190899188859390909190869391909181869190919090899090908982899790918890899088929080899488899090848990929088939091888881848991899089909089918981919088909091909089898890909090909092899089908690959091888699909190919190909090918899909090908982889090909290909090908989918989879193899089898092899089918589909091949292899089928789899089888390899090909191899293928589909089918290909092829097908989898989889089848990918889908491909189829292889189908590929090919391899190899192898989909790918891899288909091889690889087908990899090899691888988878989909082929789909084898892888989889090918881909091909088889189898990919190898885939090909
and it just keeps going like that till I stop the monitor. Did I fry my Arduino??? Help!
One problem is that you're missing a closing curly brace } on your loop() function. I'm not sure why this doesn't give an error message, but it probably is causing problems.
Another problem you'll have is that the calculation value/maxValue will be done using integer math because both arguments are integers. That means that you'll get an integer quotient, i.e. anything from 0 to 1022 divided by 1023 is 0; and for example, 11 / 4 is 2. Try making maxValue a float, perhaps, otherwise you can cast one of them to a float before doing the division, e.g. ((float) value) / maxValue.
Thank you! It works now.
-Tim
