I am having issues being able to take one array and copy it unto another one. The program is designed to run a scan. If int Volts[Z] is empty, it will take the newly acquired data from float voltage and store it in Volts[Z]. Then when the program is ran again, it will notice that Volts[Z] is not empty and then move on to compare the new data with the old.
int sensorPeakSum = 0;
sensorValue[ i ] = analogRead(A8);
sensorPeakSum+= sensorValue[ i ];
float voltage = (sensorPeakSum/x)* (10.0/1023.0);
up to this part of the code, it works. ![]()
now what I try to do is
if Volts[Z] == '\0'
Volts[Z] = voltage;
problem is
voltage = 0.1
Volts[Z] = 0. :~
