Float value through keypad
Hello everyone,
I’m a beginner, I need to insert a floating float on the 16x2 LCD via the 4x4 keypad. Can someone help me?
I’m having a hard time trying to figure out how to put a decimal point in an array, and how to make sure there is only 1 decimal point at a time.
#include <Wire.h>
#include <AnalogMatrixKeypad.h>
#define analogPin 0
AnalogMatrixKeypad AnMatrixKeypad(analogPin);
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
char state = 1;
int setpointpHMax;
int setpointCEMax;
int num = 1;
  Wire.begin();
  lcd.begin(16, 2);     //
  char Key = AnMatrixKeypad.readKey();
  if (Key != KEY_NOT_PRESSED)
    switch (state)
      case 1:
        switch (Key) {
          case 'A':
            lcd.clear(); Set_state(4);
          case 'B':
            lcd.clear(); Set_state(2);
          default:
            Set_state(1);
      case 2:
        switch (Key) {
          case 'A':
            lcd.clear(); Set_state(1);
          case 'B':
            lcd.clear(); Set_state(3);
          default:
            Set_state(2);
      case 3:
        switch (Key) {
          case 'A':
          case 'B':
          default:
            Set_state(3);
      case 4:
        switch (Key) {
          case KEY_NOT_PRESSED:
          case '0': case '1': case '2': case '3': case '4':
          case '5': case '6': case '7': case '8': case '9':
          case '.':
            //lcd.setCursor(0,0);
            //lcd.print(Key);
            num = num * 10 + (Key - 58); // Here the function that prints the variable on the LCD
            //lcd.setCursor(0, 1);
            //lcd.print(num);
          case 'D':
            num = 0;
            lcd.clear();
          case 'A':
          case 'B':
          default:
            Set_state(4);
      default:;
void Set_state(char index)
  state = index;
  switch (state)
    case 1: //==================== state 1
      lcd.setCursor(1, 0);
      lcd.print ("-Hidro V 1.0-");
      lcd.print ("--NDS Projetos--");
    case 2: //==================== state 2
      lcd.setCursor(3, 1);
      lcd.print("dgsdgsdg");
      lcd.setCursor(0, 0);
    case 3: //==================== state 3
      lcd.print(" Set Point Max");
      lcd.print("CE:");
      lcd.print(    setpointCEMax, DEC);
      lcd.print("   dS/m");
    case 4: //==================== state 4
      lcd.print("pH:");
      lcd.print( num, DEC);
      lcd.print("   dS/m");
