I have built a home thermostat with a BME280 sensor module.
I make use of an LCD to print the current temp and change my target temp with a rotary encoder.
I take temp measurements every 2 seconds and update the lcd characters every 200ms.
This is the code that reads the bme280 temp.
void readBME280(){
bme.takeForcedMeasurement();
temperature = bme.readTemperature();
if (!((temperature >= 0) && (temperature <= 35))) error = 1;
If the temperature is out of the minimum and maximum acceptable values I set “error = 1”. If so I stop heating process and I print the “problematic” measurement on the lcd.
Here are parts of my loop() and updateLCD() functions.
After a few days of operation I got an error (error = 1) which means it got an unacceptable temp measurement. On the screen I saw a measurement = -214748368.0
That used to happen more often while I was testing my code and I noticed I had set the temperature variable as double. I changed it to float (like it was in Adafruit_BME280 examples) and I thought it got fixed but the problem appeared again after ~1week continuous operation.
What could cause this? What could -214748368.0 mean?
Could this mean it wasn’t able to communicate with the sensor?
Post all of your code - too hard to deduce anything from snippets. 214748368 is a suspicious looking number - looks like a maxed out (or perhaps minned out) 32 bit int.
I didn’t post my complete code because it’s over 1000 lines and the most of it is unrelevant to my problem.
I removed everything unrelevant to temp measurements from my code and tried this minimized code which appears to have the same issue.
#include <Arduino.h>
#include <SPI.h>
#include <Wire.h>
#include <U8g2lib.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <EEPROM.h>
#define ON 1
#define OFF 0
float temperature = 0;
float target = 22.0;
int error = 0;
int heating = OFF;
unsigned long currentMillis;
unsigned long previousMillis;
unsigned long previousLCDMillis;
Adafruit_BME280 bme;
const int relay = 5;
const int backlightPin = 6;
U8G2_ST7565_64128N_F_4W_SW_SPI u8g2(
U8G2_MIRROR,
/* clock=*/ 13,
/* data=*/ 11,
/* cs=*/ 10,
/* dc=*/ 9,
/* reset=*/ 8);
void setup(void) {
pinMode(relay, OUTPUT);
digitalWrite(relay, HIGH);
pinMode(backlightPin, OUTPUT);
digitalWrite(backlightPin, HIGH);
u8g2.begin();
u8g2.setContrast(170);
bool status;
status = bme.begin(0x76); //The I2C address of the sensor I use is 0x76
bme.setSampling(Adafruit_BME280::MODE_FORCED,
Adafruit_BME280::SAMPLING_X1, // temperature
Adafruit_BME280::SAMPLING_X1, // pressure
Adafruit_BME280::SAMPLING_X1, // humidity
Adafruit_BME280::FILTER_OFF,
Adafruit_BME280::STANDBY_MS_1000);
currentMillis = millis();
if (!error){
if ( ! heating ){
if (target > temperature){
heatingON();
else{
if (target < temperature){
heatingOFF();
if ((unsigned long)(currentMillis - previousMillis) >= 2000) {
readBME280();
else heatingOFF();
if ((unsigned long)(currentMillis - previousLCDMillis) >= 200) {
previousLCDMillis = currentMillis;
updateLCD();
void heatingON(){
heating = ON;
digitalWrite(relay, LOW);
void heatingOFF(){
heating = OFF;
void readBME280(){
void updateLCD(){
u8g2.clearBuffer();
u8g2.setFont(u8g2_font_freedoomr25_tn);
u8g2.setFontMode(1);
u8g2.setDrawColor(1);
if (!error){
u8g2.setCursor(2,29);
u8g2.print(temperature,1);
u8g2.setCursor(2,63);
u8g2.print(target,1);
else{
u8g2.drawStr(2,63,"ERROR!");
u8g2.sendBuffer();
I’m pretty sure that -214748368.0 is a minned out value but I don’t know how the Adafruit_BME280 library reads data from my sensor and why it returns that minned out value.
I’d like to know if it could be a hardware related issue. Could this mean that it doesn’t find a connected sensor?
Please, be specific -- BME280 is a Pressure/Temperature/Humidity sensor. Do you have problem to read the values of this sensor using Adafruit_BME280.h Library?
GolamMostafa:
Yes. It was happening very often when temperature variable was double. I set it to float and it happened again after 1 week continuous operation. I don't know if the change from double to float did any difference.
wildbill:
There is a possibility that readTemperature will return NAN. You should probably check for it.
What would it print if it returns NAN? How could I check it since I don't know how to trigger that issue?
You can set a float to NAN and try printing it on your display. I'm wondering if that's where the 214748368 comes from although on my LED display, it just shows as "nan". To check it, use isnan().
rojoiko:
Are you using UNO or NANO or MEGA or DUE? For DUE, double is 64-bit floating point format (binary64) and float is 32-bit format (binary32). For UNO/NANO/MEGA double and float are the same, and it is 32-bit format (binary32).
wildbill:
Thanks for your suggestions.
I set another variable to NAN and printed it. It shows "nan" on the screen.
I removed everything in this function and kept the "return NAN" so it will always return NAN.
It actually printed -214748368.0 on the screen.
I don’t know why it prints NAN and -214748368.0 in these two cases.
I will check the readings with isnan() and I will discard them if they are not acceptable. I will also count how many of the readings where discarded and print that value on the screen to see how often it happens. It’s so rare (1 time in the last week) that I cannot replicate it for now.
