rd369
May 28, 2020, 8:08pm
1
float B = 3950;
void setup() { }
void main()
float bee = 1 /B;
Serial.println(bee);
using calculator I got bee value as 2.53164557e-04
but while compiling the code "bee" value becomes zero. Why?
tried to specify the decimal value in Serial.println and it works > Serial.println(bee,6);
but if there is one more equation say, "float alpha = 500 * bee;" and not printing it in Serial.println, the value becomes zero.
how to read all decimal values?
I get .000253
Probably not the math but the print statement rounding it off.
-jim lee
rd369
May 28, 2020, 9:01pm
4
jimLee:
I get .000253
-jim lee
Yeah, just noticed it, sorry and thanks. I changed the value but the problem is still there.
https://forum.arduino.cc/index.php?topic=687073.0
Check this topic, and you'll understand why i asked.
rd369:
thermistor value to servo motor, not getting value - Programming Questions - Arduino Forum
int roomTemp = 28+273.15; // Room Temperature (Kelvins)
float sum = (1/roomTemp) + productTerm; // 1/T0 + 1/Bln(r1/r0)
Since 'roomTemp' is an integer and greater than 1, the sub-expression "(1/roomTemp)" is going to be zero.
As a best practice, I only use floats in float expressions, since mixing ints and floats sometimes gives unexpected results (truncation errors). Perfect example is the thread you linked.
instead of
float bee = 1 /B;
I'd write
float bee = 1. /B;
rd369:
Can you provide an Arduino sketch that demonstrates the problem?
