Hello! Given the following code:
char latit[10] = {"4041.2358"}; //Degrees = 40, Minutes = 41, Seconds = 23.58
Serial.print("latit = ");
Serial.println(latit);
float flatit = atof(latit);
Serial.print("flatit = ");
Serial.println(flatit, 6);
flatit /= 100.00;
float flatitdegrees = (int)flatit; //isolate degrees
float temp = (flatit - (int)flatit) * 100;
float fminutes = (int)(temp); //isolate minutes
float fseconds = (temp - fminutes) * 100; //isolate seconds
Serial.print("Degrees = ");
Serial.println(flatitdegrees);
Serial.print("Minutes = ");
Serial.println(fminutes,2);
Serial.print("Seconds = ");
Serial.println(fseconds, 2);
I get an output that looks like this:
latit = 4041.2358
flatit = 4041.235839
flatit = 40.412357
Degrees = 40.00
Minutes = 41.00
Seconds = 23.57
Can someone help me to understand what is going on with those last significant digits?
system
January 20, 2013, 3:13pm
#2
A float has between 6 and 7 digits of precision. You string has 8. Converting it to a float does not produce and exact value, with 8 digits of precision.
Using Serial.print() to print more digits does not result in more precision, just more guesswork.
The results you are getting are exactly what I'd expect.
floating points are just not as precise as you want them to be.
The Arduino (UNO) uses IEEE-754 float format = 32 bits
1 bit for sign
23 bit for the fraction
8 bit for exponent (powers of 2)
the fraction part can only hold about 7 digits precision. YOur number has 8 so it is rounded to the nearest number it can represent.
Details see Wikipedia - http://en.wikipedia.org/wiki/IEEE_754-1985 -
Thanks everyone for the great explanations. Quick and easy fix in my code was to separate the digits before and after the decimal using the decimal as the delimiter and then working the math on each section individually. Works perfect now!
system
January 20, 2013, 4:56pm
#5
Floating point math issues....last significant digit not what I expected
It would have been a miracle if t he last significant digit were what you expected. That's the nature of floating point math.
And we haven't even discussed error propagation due to math operators
