I have a function below that uses floating point numbers D1 and D2. They are variables in an equation.
I don't want to use floats I am constrained for memory on the embedded platform I developing for (floating point library is large). I would only like to use ints. So the function would return an int and use ints in the calculation.
For example instead of 22.95 degrees the function would return 229500 degrees.
Would anybody know how I calculate what values D1 and D2 should become?
float SHT1x::readTemperatureC()
int _val; // Raw value returned from sensor
float _temperature; // Temperature derived from raw value
// Conversion coefficients from SHT15 datasheet
const float D1 = -40.0; // for 14 Bit @ 5V
const float D2 = 0.01; // for 14 Bit DEGC
// Fetch raw value
_val = readTemperatureRaw();
// Convert raw value to degrees Celsius
_temperature = (_val * D2) + D1;
return (_temperature);
int SHT1x::readTemperatureC()
const int D1 = ?; // for 14 Bit @ 5V
const int D2 = ?; // for 14 Bit DEGC
// Fetch raw value
