flood warning device using cb radio
how to test my jz863 mini power transciever with my arduino..can you give me a sample program?tnx..
Have you read the sticky note at the top of the forum?
I cannot find the links to the hardware and a project description in your post...
google
arduino jz836
http://www.luntianlaboratory.com/arduino/arduino-rf-module-sketch/
read all you can, make the board, test it.
ps: thanks to all those who have put up with my simple questions.
Using CB bands to transmit data is illegal.
ITLE 47--TELECOMMUNICATION
COMMISSION (CONTINUED)
PART 95--PERSONAL RADIO SERVICES--Table of Contents
Subpart D--Citizens Band (CB) Radio Service
Sec. 95.412 (CB Rule 12) What communications may be transmitted?
(a) You may use your CB station to transmit two-way plain language
communications. Two-way plain language communications are communications
without codes or coded messages
based on the question, I think we assume the OP has a clue.
CB frequencies are 26.965 MHz to 27.405 MHz
the JZ863 has a carrier frequency of 433MHz?also capable of providing 315/868/915MHz carrier frequency
the OP is probably going to find out about GSM, but I think we have already given way more energy into this post than the OP did to try to find how to do the project.
is it possible that were going to transmit a frequency signal via JZ863 to the UHF cb radio?
reynabeth321:
No.
