Floor Area Sensor
is there any sensor that can calculate the floor area?
Of a building? Of a room?
In general, there isn't any sensor that can sense any floor area.
Some laser range finders can computer room area or volume from length x width (x height) measurements.
I'm trying to build a distance meter of 100 meters, but the sensors that I know have a very small range, Telémetro láser LIDAR-Lite 3 40 Mts
Please do not hijack threads.
Google will show you long distance laser rangers.
Argel20:
You can combine a fluid level sensor and a flow meter, pumping water into the room and seeing the
ratio between the volume of water pumped and the depth change in the same period. This works
for waterproof rooms of any shape. :slight_smile:
You can also use Bosch laser measure. It can be connected to free Bosch Measuring Master App which has functions of:
  • Area calculation
  • Detailed Plans: Floor plan creation including wall view, room height, roof slope and area calculation
More info about the App here and info about the device here.
