I want to make a robot car which detects the water on the floor, wipes it clean and then moves forward only after wiping it fully.
I am planning to use this sensor:
My main question is that can I use the moisture sensor in the link to detect water on the floor? If anyone has used this sensor for this application, or otherwise, please give me your piece of mind.
These "brick" sensors use an opamp so the sensitivity is adjustable. It should work but the probe that is included with it isn't practical for a mobile robot; you'd probably want to make your own with a couple strips of metal dragging on the floor.
It'd be worth your time understanding how the module works. All you need is an inexpensive opamp and a few resistors/caps to build your own.
