sirbow2
December 22, 2011, 5:47pm
1
i have a floppy motor and driver like: http://sturntech.com/blog/2010/12/04/reverseengineering-fd1231h-floppy-disk-spindlemotor-controller/
i figured out that if i loop LOW then HIGH with no delays on the CLK pin with the arduino(vcc etc hooked up too), it will turn the motor. but its really laggy, how can i speed up the LOW/High switching of the digital pin and thus make the motor spin "better"?
Use direct port access rather than the digitalWrite function.
The Arduino programming language Reference, organized into Functions, Variable and Constant, and Structure keywords.
sirbow2
December 22, 2011, 6:30pm
3
ok so i have clock on pin 9 and using the old digitalwrite code it works, but if i use this:
int DlY=10;
DDRB=11111111; //sets 8-13 as output
PORTB = B11111111; //sets 8-13 as high
delay(DlY);
PORTB = B00000000; //sets 8-13 as low
delay(DlY);
it doesn't...how long does it take for a normal digitalwrite? ive confirmed that the pin is actually cycling.
system
December 22, 2011, 7:27pm
4
Orders of magnitude less than the delay().
sirbow2
December 22, 2011, 8:07pm
5
the website i linked before said to put a 1mhz clock on this pin, am i even doing the right thing toggleing LOW/HIGH?
hmmm thats strange, before with no delays and new code it wouldnt turn, now it does but very slowly but its smooth...
system
December 22, 2011, 8:09pm
6
I hope it said 1MHz, and not 1mHz
So it looks like it is producing pulses that are too fast without the delay.
sirbow2
December 22, 2011, 10:54pm
9
im so very confused.. O-scope would be so nice right now...
can you help a little more?
system
December 22, 2011, 11:11pm
10
You have a 10 millisecond delay. Try cutting that down to smaller delays. If one millisecond delay is still too long (i.e. the speed is not where you want), you can use delayMicroseconds() to get shorter delays.
If shorter delays don't help, more voltage, or current, or both might.
