FLORA LSM9DSO-Gyros Sensor+Arduino Uno
Hello,
I have a new project based on gyro sensor
I have the FLORA LSM9DSO model…
I downloaded the library of adafruit on gitHub,
and I tried to flash the exemple “sensorapi” who attach to the library zip file
The values that I get not looks correct for some reason…
I would like to ask you guys/laidies if you can help me to understand how this sensor works
This is the serial plot
The sensor have no movement in this time
The code on arduino:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM9DS0.h>
/* This driver uses the Adafruit unified sensor library (Adafruit_Sensor),
   which provides a common 'type' for sensor data and some helper functions.
   To use this driver you will also need to download the Adafruit_Sensor
   library and include it in your libraries folder.
   You should also assign a unique ID to this sensor for use with
   the Adafruit Sensor API so that you can identify this particular
   sensor in any data logs, etc.  To assign a unique ID, simply
   provide an appropriate value in the constructor below (12345
   is used by default in this example).
   Connections (For default I2C)
   Connect SCL to analog 5
   Connect SDA to analog 4
   Connect VDD to 5V DC
   Connect GROUND to common ground
   History
   2014/JULY/25  - First version (KTOWN)
/* Assign a unique base ID for this sensor */
Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0(1000);  // Use I2C, ID #1000
/* Or, use Hardware SPI:
  SCK -> SPI CLK
  SDA -> SPI MOSI
  G_SDO + XM_SDO -> tied together to SPI MISO
  then select any two pins for the two CS lines:
#define LSM9DS0_XM_CS 10
#define LSM9DS0_GYRO_CS 9
//Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0(LSM9DS0_XM_CS, LSM9DS0_GYRO_CS, 1000);
/* Or, use Software SPI:
  G_SDO + XM_SDO -> tied together to the MISO pin!
  then select any pins for the SPI lines, and the two CS pins above
#define LSM9DS0_SCLK 13
#define LSM9DS0_MISO 12
#define LSM9DS0_MOSI 11
//Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0(LSM9DS0_SCLK, LSM9DS0_MISO, LSM9DS0_MOSI, LSM9DS0_XM_CS, LSM9DS0_GYRO_CS, 1000);
    Displays some basic information on this sensor from the unified
    sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
  sensor_t accel, mag, gyro, temp;
  lsm.getSensor(&accel, &mag, &gyro, &temp);
  Serial.println(F("------------------------------------"));
  Serial.print  (F("Sensor:       ")); Serial.println(accel.name);
  Serial.print  (F("Driver Ver:   ")); Serial.println(accel.version);
  Serial.print  (F("Unique ID:    ")); Serial.println(accel.sensor_id);
  Serial.print  (F("Max Value:    ")); Serial.print(accel.max_value); Serial.println(F(" m/s^2"));
  Serial.print  (F("Min Value:    ")); Serial.print(accel.min_value); Serial.println(F(" m/s^2"));
  Serial.print  (F("Resolution:   ")); Serial.print(accel.resolution); Serial.println(F(" m/s^2"));
  Serial.println(F(""));
  Serial.print  (F("Sensor:       ")); Serial.println(mag.name);
  Serial.print  (F("Driver Ver:   ")); Serial.println(mag.version);
  Serial.print  (F("Unique ID:    ")); Serial.println(mag.sensor_id);
  Serial.print  (F("Max Value:    ")); Serial.print(mag.max_value); Serial.println(F(" uT"));
  Serial.print  (F("Min Value:    ")); Serial.print(mag.min_value); Serial.println(F(" uT"));
  Serial.print  (F("Resolution:   ")); Serial.print(mag.resolution); Serial.println(F(" uT"));
  Serial.print  (F("Sensor:       ")); Serial.println(gyro.name);
  Serial.print  (F("Driver Ver:   ")); Serial.println(gyro.version);
  Serial.print  (F("Unique ID:    ")); Serial.println(gyro.sensor_id);
  Serial.print  (F("Max Value:    ")); Serial.print(gyro.max_value); Serial.println(F(" rad/s"));
  Serial.print  (F("Min Value:    ")); Serial.print(gyro.min_value); Serial.println(F(" rad/s"));
  Serial.print  (F("Resolution:   ")); Serial.print(gyro.resolution); Serial.println(F(" rad/s"));
  Serial.print  (F("Sensor:       ")); Serial.println(temp.name);
  Serial.print  (F("Driver Ver:   ")); Serial.println(temp.version);
  Serial.print  (F("Unique ID:    ")); Serial.println(temp.sensor_id);
  Serial.print  (F("Max Value:    ")); Serial.print(temp.max_value); Serial.println(F(" C"));
  Serial.print  (F("Min Value:    ")); Serial.print(temp.min_value); Serial.println(F(" C"));
  Serial.print  (F("Resolution:   ")); Serial.print(temp.resolution); Serial.println(F(" C"));
    Configures the gain and integration time for the TSL2561
void configureSensor(void)
  // 1.) Set the accelerometer range
  lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_2G);
  //lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_4G);
  //lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_6G);
  //lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_8G);
  //lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_16G);
  // 2.) Set the magnetometer sensitivity
  lsm.setupMag(lsm.LSM9DS0_MAGGAIN_2GAUSS);
  //lsm.setupMag(lsm.LSM9DS0_MAGGAIN_4GAUSS);
  //lsm.setupMag(lsm.LSM9DS0_MAGGAIN_8GAUSS);
  //lsm.setupMag(lsm.LSM9DS0_MAGGAIN_12GAUSS);
  // 3.) Setup the gyroscope
  lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_245DPS);
  //lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_500DPS);
  //lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_2000DPS);
    Arduino setup function (automatically called at startup)
void setup(void)
#ifndef ESP8266
  while (!Serial);     // will pause Zero, Leonardo, etc until serial console opens
#endif
  Serial.println(F("LSM9DS0 9DOF Sensor Test")); Serial.println("");
  /* Initialise the sensor */
  if(!lsm.begin())
    /* There was a problem detecting the LSM9DS0 ... check your connections */
    Serial.print(F("Ooops, no LSM9DS0 detected ... Check your wiring or I2C ADDR!"));
    while(1);
  /* Setup the sensor gain and integration time */
  configureSensor();
  /* We're ready to go! */
  Serial.println("");
    Arduino loop function, called once 'setup' is complete (your own code
    should go here)
void loop(void)
  /* Get a new sensor event */
  sensors_event_t accel, mag, gyro, temp;
  lsm.getEvent(&accel, &mag, &gyro, &temp);
  // print out accelleration data
  Serial.print("Accel X: "); Serial.print(accel.acceleration.x); Serial.print(" ");
  Serial.print("  \tY: "); Serial.print(accel.acceleration.y);       Serial.print(" ");
  Serial.print("  \tZ: "); Serial.print(accel.acceleration.z);     Serial.println("  \tm/s^2");
  // print out magnetometer data
  Serial.print("Magn. X: "); Serial.print(mag.magnetic.x); Serial.print(" ");
  Serial.print("  \tY: "); Serial.print(mag.magnetic.y);       Serial.print(" ");
  Serial.print("  \tZ: "); Serial.print(mag.magnetic.z);     Serial.println("  \tgauss");
  // print out gyroscopic data
  Serial.print("Gyro  X: "); Serial.print(gyro.gyro.x); Serial.print(" ");
  Serial.print("  \tY: "); Serial.print(gyro.gyro.y);       Serial.print(" ");
  Serial.print("  \tZ: "); Serial.print(gyro.gyro.z);     Serial.println("  \tdps");
  // print out temperature data
  Serial.print("Temp: "); Serial.print(temp.temperature); Serial.println(" *C");
  Serial.println("**********************\n");
  delay(250);
The sensor needs calibration values..
Your reading are probaly OK.
For the gyro (when sensor is completly still) : add values so all return Zero
The accelerometer. take not of max/min values when sensor is positioned (and kept still) in the 6 possible positions u can place a cube
The magnetometer requires a special procedure.. found in this forum
