Good day,
Is there someone that can help with code on the flow chart attached.
It is a simple project for replacing a ice machine controller board which damaged with power surge.
Ice Machine Flow Chart.pdf (20.1 KB)
Good day,
In Short want to use Uno Arduino to do this.
Pin assignments:
d2 - water sense - Input
d3 - compressor relay - Output
d4 - Water Relay - Output
d5 - Solenoid Relay - Output
d6 - Fan Relay - Output
d7 - Pump Relay - Output
Relay’s switch on LOW,
State off all relays on startup - OFF (High)
What I did so far, but not working as it should.
// and the current state of the SOL
int ws = 2;
int wr= 4;
int readVal; //test phase
float V2; //test phase
int wrState = LOW; // Water Level State
int wsState = LOW;
unsigned long previousMillis0 = 0; // will store last time water inled
long OnTimewr = 3000; // milliseconds of on-time
long OffTimewr = 1000; // milliseconds of off-time
unsigned long MasterMillis = 0; // will store last time SOL was updated
int solPin = 5; // the number of the SOL pin
int solState = HIGH; // solState used to set the SOL
unsigned long SolPreviousMillis = 0; // will store last time SOL was updated
long SolOnTime = 120000; // milliseconds of on-time
long SolOffTime = 1740000; // milliseconds of off-time
// Fan Variables follow
int fanPin = 6; // the number of the FAN pin
int fanState = HIGH; // fanState used to set the FAN
unsigned long FanPreviousMillis = 0; // will store last time FAN was updated
long FanOnTime = 1500000; // milliseconds of on-time
long FanOffTime = 240000; // milliseconds of off-time
// These variables store the flash pattern
// and the current state of the PUMP
int pumpPin = 7; // the number of the PUMP pin
int pumpState = HIGH; // pumpState used to set the PUMP
unsigned long PumpPreviousMillis = 0; // will store last time PUMP was updated
long PumpOnTime = 1560000; // milliseconds of on-time
long PumpOffTime = 180000; // milliseconds of off-time
Serial.begin (9600);
pinMode(ws, INPUT);
pinMode(wr, OUTPUT);
// set the digital pin as output:
pinMode(solPin, OUTPUT);
pinMode(fanPin, OUTPUT);
pinMode(pumpPin, OUTPUT);
readVal=digitalRead(ws);
V2=(5./1023.)*readVal;
Serial.print("Level is ");
Serial.print(readVal);
if(readVal==1) //digitalRead(ws == HIGH)) //(wsState == HIGH) && (wrState == HIGH)) //&& (currentMillis - previousMillis0 >= SolOn))
wrState = LOW; // Turn it off
// previousMillis1 = currentMillis; // Remember the time
digitalWrite(wr, wrState); // Update the actual LED
else if (readVal==0) //digitalRead(ws == LOW)) //(wrState == LOW) && (wrState == LOW)) //&& (currentMillis - previousMillis0 >= SolOff))
wrState = HIGH; // turn it on
//readVal=digitalRead(watersense);
//V2=(5./1023.)*readVal;
//Serial.print("Level is ");
//Serial.println(readVal);
//if (readVal==1){
// digitalWrite(waterrelay,HIGH);
//if (readVal==0){
// digitalWrite(waterrelay,LOW);
// check to see if it’s time to change the state of the SOL
unsigned long SolMillis = millis();
if((solState == HIGH) && (SolMillis - SolPreviousMillis >= SolOnTime))
solState = LOW; // Turn it off
SolPreviousMillis = SolMillis; // Remember the time
digitalWrite(solPin, solState); // Update the actual SOL
else if ((solState == LOW) && (SolMillis - SolPreviousMillis >= SolOffTime))
solState = HIGH; // turn it on
// check to see if it’s time to change the state of the FAN
unsigned long FanMillis = millis();
if((fanState == HIGH) && (FanMillis - FanPreviousMillis >= FanOnTime))
fanState = LOW; // Turn it off
FanPreviousMillis = FanMillis; // Remember the time
digitalWrite(fanPin, fanState); // Update the actual FAN
else if ((fanState == LOW) && (FanMillis - FanPreviousMillis >= FanOffTime))
fanState = HIGH; // turn it on
// check to see if it’s time to change the state of the PUMP
unsigned long PumpMillis = millis();
if((pumpState == HIGH) && (PumpMillis - PumpPreviousMillis >= PumpOnTime))
pumpState = LOW; // Turn it off
PumpPreviousMillis = PumpMillis; // Remember the time
digitalWrite(pumpPin, pumpState); // Update the actual PUMP
else if ((pumpState == LOW) && (PumpMillis - PumpPreviousMillis >= PumpOffTime))
pumpState = HIGH; // turn it on
