Flow control check
Hi
I have put together a sketch, but when I hook everyting up it does not work as I intended. Can anyone have a look at it and see if there is a error somewhere? And please keep in mind that I am new at this and for the most part I have no idea what I'm doing :slight_smile:
A little bit of my project: I am building av flow control, that controls how much water flows through a valve. Let's say I'm going to fill a vessel with 40 liters of water, I can adjust the amount up and down with two buttons, when the amount is set I press another button to open an electric valve and start the water flow. When the amount passed through the sensor/valve reaches the set amount, it triggers an effect that closes the electric valve. The fourth button is just a reset button.
I use a 16x2 i2c lcd display to see the adjustments and flow. I also use two relays to control the electric valve. The valve is 12volts and the rest is 5 volts.
I power everyting with a 12volt 1.5A power supply.
If anyone wants to have a look at it, I can e-mail the sketch because it is to big to post here.
thank you
You can use the attach option to post the code.
Along with using the Reply button, not the Quick Reply field, you need to elaborate.
"it does not work as I intended" doesn't mean anything (except that you are frustrated).
What does it do? How does that differ from what you want?
A schematic would be useful to - a Fritzing diagram or the (really) old-fashioned pencil on paper kind.
