Flowmeter with no interrupts 32U4
Hi guys!
I have a question and I need some help, I triend many times but obtained zero results.
I want to measure two waterflows through two pipes with two flowmeters connected to an Arduino Pro Micro, those one with a spinning wheel, that means, the flow is linear related with the frequency. I have the formula, but not the way to measure the frequency.
The problem is I CAN NOT USE INTERRUPTS, I am hardware forced to use pin D6 and D7. D7 has INT but D6 has no INT nor PCINT.
So, how can I proceed to measure the flow without blocking to much the other sensors reading (temperature, pressure etc) and I2C JSON sending to a connected RaspberryPi?
Thanks in advance, everything works, but I didn´t find the way to implement this...
Greetings!
Raphael M. Trautmann
Can you use pin change interrupts (there's a library) on the Pro Micro?
I guess, but pin D6 does not work with PCINT...
Just poll the pins. No need for interrupts with a flowmeter.
Of course, you will not be able to use delay() in the polling loop, or you will miss pulses.
What makes you believe this?
No INT or PCINT on pin 6 here: https://www.arduino.cc/en/Hacking/PinMapping32u4.
Pin 6 is not in the list here: Usage · GreyGnome/EnableInterrupt Wiki · GitHub.
@RTDesigns, why are you forced to use pin 6 ?
Can you cheat a little by connecting another pin to pin 6 ?
The solution by jremington (just poll the pins) should work. What is the maximum frequency and the minimal pulse duration of the flow meter ? Can you show the sketch ?
I would just do as post #3 suggest. Your flow sensor outputs a number of pulses per unit of flow. So measure the High time and Low time on a pin. High time + Low time is the period and 1/Period is the frequency. Now depending on the sensor K factor (pulses per unit of measure) you derive the flow rate. You do not need an interrupt to measure flow.
Ron
jremington:
Yeah I know, I should do it with millis(). Okay thanks a lot!! I wil try!!!! :slight_smile:
Koepel:
I am forced to use this pins because I designed and ordered a PCB, with this asignations.
For now I didn´t calculate frequency or pulse duration, but I guess not very high frequency, because its a flowmeter in a piping with a lower flowrate than the water coming from a water tap.
I didn´t have anything done with this in the sketch, just this:
  • Caudales: 2 sensores, caudalímetro
    // Pines asociados
    const static byte FLOW1_PIN = 6;
    const static byte FLOW2_PIN = 7;
    // Número de sensores
    const static byte FLOW_NMETERS = 2;
    // Valor de las medidas
    float flowMeasures[FLOW_NMETERS];
    // Para debug
void printFlows();
I can´t cheat pins because everyone is assigned, I have about 9 temperature sensors, 4 pressure sensors, etc...
I will try like you guys told me, polling!! Thanks!
Ron_Blain:
Ron
Thanks!! I will try this yeah!
