fluctuation in values of potentiometer/knob
Hi All,
I have connected a potentiometer/knob to arduino. the circuit is doing perfect. When I am uploading AnalogInOutSerial from the examples>analog, I can see the values of the potentiometer in the serial monitor.
However I have noticed that the values of the potentiometer are fluctuating even if I do not rotate the potentiometer/knob.
Can someone please explain the cause for this and also the solution.
Thanks,
shanky
Over what range? A variation of +/- 1 in the output of analogRead() is normal/expected. A larger variation is not.
That depends on what the problem is. Why is the variation causing you problems?
i also get that.
maybe you can get someone else to explain you why it happens (i actually have no idea. i think something to do with how the voltave is mapped into the value range of the pot, but i maybe be super wrong!!!)
Maybe you could put your
  analogWrite(analogOutPin, outputValue);
inside a if statment. something like:
const int analogInPin = A0;
const int analogOutPin = 9;
int mappedPotValue = 0;
int noFloat = 2;
int lastPotValue = 0;
int currentPotValue = 0;
  currentPotValue = analogRead(analogInPin);
  mappedPotValue = map(currentPotValue, 0, 1023, 0, 255);
  if (abs(mappedPotValue - lastPotValue) >= noFloat) {
    analogWrite(analogOutPin, currentPotValue);
    Serial.print("sensor = " );
    Serial.print(currentPotValue);
    Serial.print("\t output = ");
    Serial.println(currentPotValue);
    lastPotValue = mappedPotValue;
But i am a really noob, so please take my advice with caution! :wink:
That seems like an unnecessary way to shift the value to the left by two:
mappedPotValue = currentPotValue >> 2
Thank You to all for replying.
@PaulS : That depends on what the problem is. Why is the variation causing you problems?
Well I am controlling a flash animation through the potentiometer/knob. Since the x direction of the movieclip is dependent on the value of the potentiometer/knob, the variation in the values of potentiometer/knob makes the animation to shake, giving it a weird feel. This is a problem for me. The variation is +/- 1.
Shanky
You could average a number of readings, or perform a rolling average.
The below is for using pots to control servos, but may be similar to what you are doing. The code has a dead band setup that filters out the small variations seen to limit hunting behavior. The code has a delay so the output and changes are more easily seen on the serial monitor for testing. You don't have to have servos attached to try the code.
//zoomkat dual pot/servo test 12-29-12
//view output using the serial monitor
#include <Servo.h>
Servo myservo1;
Servo myservo2;
int potpin1 = 0;  //analog input pin A0
int potpin2 = 1;
int newval1, oldval1;
int newval2, oldval2;
  myservo1.attach(2);
  myservo2.attach(3);
  Serial.println("testing dual pot servo");
  newval1 = analogRead(potpin1);
  newval1 = map(newval1, 0, 1023, 0, 179);
  if (newval1 < (oldval1-2) || newval1 > (oldval1+2)){
    myservo1.write(newval1);
    Serial.print("1- ");
    Serial.println(newval1);
    oldval1=newval1;
  newval2 = analogRead(potpin2);
  newval2 = map(newval2, 0, 1023, 0, 179);
  if (newval2 < (oldval2-2) || newval2 > (oldval2+2)){
    myservo2.write(newval2);
    Serial.print("2- ");
    Serial.println(newval2);
    oldval2=newval2;
  delay(50);
