Flummoxed
I will put up two pieces of code using TIMER1 in CTC mode. One is in the c style and the other written in Arduino style.
int main(void) {
  DDRD |= (1 << PD7);
  TCCR1B |= (1 << WGM12); //Configure Timer1 for CTC
  TIMSK |= (1 << OCIE1A); // Enable CTC interrupt
  sei(); //enable global interrupt
  OCR1A = 15624; // set CTC compare value to 1 Hz at 16 MHz clock and prescalar of 1024
  TCCR1B |= ((1 << CS10) | (1 << CS11));
  for (;;) {
ISR(TIMER1_COMPA_vect)  {
  PORTD ^= (1 << PD7);
This uploads and the Led on PD7 toggles as programmed.
The second code
  DDRD |= (1 << PD7);//DDR for PD7
  sei();
  PORTD ^=(1<<PD7);// Toggle PD7
This code compiles and uploads fine but the Led toggle is missing
Will appreciate clarity in this.
Regards.
When you use the Arduino environment, you enable certain Timer preset values to support the standard PWM outputs controlled with analogWrite(). It is good practice when writing custom Timer1 code to remove all the presets with TCCR1A = 0 and TCCR1B = 0. Your prescalers were wrong for 1024 and were actually at 64.
  TCCR1A = 0;
  TCCR1B = 0;
  TIMSK1 |= (1 << OCIE1A); // Enable CTC interrupt
  sei();
  TCCR1B |= ((1 << CS10) | (1 << CS12));
Thanks a ton, cattledog, clearing the presets is important. You made my day the second time today, appreciate it.
Note: To toggle an output pin:
  PORTD ^= (1<<PD7); // Toggle PD7
can be replaced with:
  PIND = (1<<PD7); // Toggle PD7
This is a hardware feature of AVR output pins and avoids a read/modify/write cycle. The PIN register is the register you use to read input pins. When you write to it, any bit written with a 1 gets toggled and the other bits are left unchanged.
Yes johnwasser,
I am just begining to get a hang of Bit Math, is the reason of experimenting with C type code on the Arduino platform, I use MCUDUDE's minicore.
