FLYSKY CT6B with ARDUINO UNO
HI actually i was working on a project where i use flysky ct6b receiver with arduino uno for the free rider FPV game i am not able to find any code and wire connections for this project and even the programming cable of the transmitter is not working. Can you please tell the wire connections and code for this project (the receiver does not have a specific pin for PPM signal).
Please read the topic "How to get the best out of this forum" and follow the advice.
Can you provide details of what it is you are trying to achieve.
As far as I am aware, there is no programming cable for the Flysky tx (FS-i6) that normally accompanies the receiver you quoted.
There is a trainer port input, wiring connections which may be what you require.
https://clover.coex.tech/en/trainer_mode.html
the programming cable for the transmitter.
Screenshot 2023-06-10 080058
It is not working for me.
Ah, now I know what you are on about.
t6a-electronic_manual.pdf (3.4 MB)
Probably lack of drivers for the usb ........not a brilliant video but better than nothing I guess.
https://www.youtube.com/watch?v=YaFeqPcZmfk
It's pretty old stuff now but anyhow this link might help get the T6 config execute file.......
https://www.rcyachts.com/KitInfo/T6Confg/T6Config.htm
Tx circuit diagram if that helps......
This might assist you as well..............
https://www.flitetest.com/articles/programming-the-hk-6ch-2-4ghz-v2-tx
but when i plug the programming cable the led is not oning.
Thank you everyone for helping the issue was resolved.
For future reference it would be good practice to mention this aspect first up, not last and after the fact.
