Can anyone recommend some good options on FM radio receiver module breakout boards with the following features:
Arduino Compatible - Digital control
RDS decoding
Digital frequency and volume control
Good reception
Dedicated antenna connection
I'm currently using a Si4703 breakout board, the main issue I'm having is the antenna being integrated into the the audio output.
I'd like to be able fit a proper dedicated antenna for areas where radio reception is not as good.
The RDA5807FP shown in this post has separate antenna pin and can decode RDS. You can pick them up as modules from AliExpress or eBay but the eBay ones will require a bit of soldering to make them breadboard friendly or connectable.
