FM transmitter
Hi :slight_smile:
I'm thinking of making my own fm transmitter (tiny range) and as I have never worked with 100Mhz, I realized I need the help of more qualified people.
One fm modulator I really like is the armstrong one:
(Sorry but the french but I believe it is easily understandable as the words look the same).
Anyway, such a diagram will need AO to phase shift or add them and I'm not sure an AO can handle 100Mhz without significantly changing the signal. Am I right?
Secondly, for a circuit like this one (just an example):
No matter which circuit I am going to use, I will need a variable capacitor to adjust the oscillation.
I've seen a lot of 'trimmer capacitor' like that:
But they all need a screwdriver, do you know something that is manually adjustable like a potentiometer.
TLDR:
  1. Can you confirm there is no easy way to phase shift/multiply/add signals which are >100Mhz?
  2. How can I have a variable capacitor (<20pF /30pF) that can be manually rotated like in a finished product (like a radio...)
Thank you very much for reading
On a 16MHz processor! Do you need to ask?
  1. How can I have a variable capacitor (<20pF /30pF) that can be manually rotated like in a finished product (like a radio...)
Yes there are lots of them. However using a free running oscillator controlled by a variable capacitor is never going to be stable enough for a transmitter.
Also transmitting in the broadcast FM bands is illegal in many countries no matter what the range.
Where in the world are you.
Why not use something like this?
http://www.karlssonrobotics.com/cart/fm-radio-module-breakout-board-ns73m/
FM modulator chips are all over the place -- you will have no trouble finding a chip or module that works in the 88-106 MHz band and does conventional broadcast FM modulation.
A variable capacitor could be a Varactor or Varicap --
Its capacitance is varied by changing a bias voltage, which could come from a potentiometer.
Grumpy_Mike:
Actually I was talking about Op-amps when I said AO sorry for that mistake, AO is the common name we use in France. The arduino is obviously not going to receive the modulated signal.
Grumpy_Mike:
Can you be more precise about it?
Moreover I don't want to make a 'real' transmitter that is going to be used, something that works well enough is ok. Unless you tell me that using a variable capacitor, I won't ever be able to send a modulated signal that can be demodulated afterwards I think it perfectly suits my needs.
Finally talking about legislation, there are quite a lot of small fm transmitter designed for smartphones being sold in physical shops. I'm aware this is not authorized but it is tolerated here in France. And as I said, the transmitter is not going to be used more than one or two minute and will be used underground.
Thank you
gardner:
The goal of that project is not the result itself but more how I manage to have a working transmitter. So I'd prefer to make it by myself.
gardner:
Varicap - Wikipedia
I've heard about it but, correct me if I'm wrong, I don't think I can change the value of the capacitance on one side and then use that specified capacitance in the oscillator.
If I replace the variable capacitor by a varicap the value of the capacitance is going to change because of the AC that is going through and I won't be able to control it, isn't it?
Thanks
florian92:
Fair enough. But that's an electronics project, not specifically an Arduino one.
One of these suit?:
http://www.electroschematics.com/5871/diy-fm-transmitter-circuits/
gardner:
One of these suit?:
[/quote]
Yeah sure, I like the one they call "low power fm transmitter"
It is also quite similar to the first circuit posted here, and that is exactly what I need for a transmitter.
About the question I still have
• Can an OP-amp handle 0->5V at 100Mhz without having a slew rate.
That would mean a minimum slew rate sigma of 5V100MHz2=1GV/S=1000V/µs which is huge
• Any idea about a variable capacitor you could manually adjust like a potentiometer (no screwdriver)
I found 'air variable capacitor' that could suit my needs but they are overpriced (50$)
• Is the capacitor replacable by a varicap, and how?
Thank you very much
Assuming you mean the Op Amp Summing Amplifier (labeled "Additioneur")(presumably French for "Adder")
You'll need an Op Amp with a high GBP (Gain Bandwidth Product).
The Linear LT1226 has a 1 Ghz GBP.
http://www.ebay.co.uk/itm/Vintage-Butterfly-Variable-Capacitor-50-50PF-NOS-/221607147028
That is not a very specific term, what is good enough?
That sounds like a typical French thing. There are laws and you ignore them. That is why the UK hate the EC they are the only ones that stick to the rules.
