Focus stacking rail problems
Hi I have a arduino sketch for a foucus stacking rail designed by Peter mobs I just can not get it to load Peter has helped me as far as he can but still stuck can any one look over the code and get it working for me please.
I belive there are quite a few lines in the program that are not needed it may be one of these?
I am over 60 and suffer from chronic depression and this is getting me so worked up
Please if any one can help contact me
There is a few videos on you tube by Peter and he has his own websight in am in the north east of England I just need the code loading I have the controller built just the code to get working
Hopefully albert
You have not posted the code
What Arduino board are you using?
Please provide an explanation of that the program is intended to do.
...R
I am away from computer for 2 days how do I upload code from an Android tablet
I know I can e-mail it if that helps
Albert
You may simply copy/paste it, and post between code tags (the </> button in the full editor).
How do I get the file open on android it says can not open file
Albert
bigal999:
Albert
I don't think that is our problem :slight_smile:
...R
hi i will have to post code in 3 files as its to long to post otherwise
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <LiquidCrystal.h>
#include <LiquidCrystal_I2C_ByVac.h>
#include <LiquidCrystal_SI2C.h>
#include <LiquidCrystal_SR.h>
#include <LiquidCrystal_SR1W.h>
#include <LiquidCrystal_SR2W.h>
#include <LiquidCrystal_SR3W.h>
#include <SI2CIO.h>
#include <SoftI2CMaster.h>
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <SI2CIO.h>
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <SI2CIO.h>
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <SI2CIO.h>
//STEPPER BOX 2 Begun 04/October 2016 - current 20th May 2017
// Global variables to have capital letters
//#define ENCODER_OPTIMIZE_INTERUPTS // Use if time overhead is crucial
#include <Encoder.h>
Encoder myencoder(2, 3); // both of these are interupt pins - gives highest fidelity
int Button_pin = 13;// pin that connects to encoder switch/button
int Upper_limit = 8; // initial max for encoder
int Lower_limit = 1; // initial min for encoder
int Increment = 10; // initial value for multilier re: durations, distance etc
int Direction; // intial direct rail will move 0 = forward
long int Distance;
int Number_photos;
int Delay_1;// Time over which railmovement settles down
int Delay_2;// Exposure time during which rail halts
int Dir_pin = 11; // Set initial pins to those for Z axes
int Drive_pin = 12; // initial pin for Z stepper motion
int Enable_pin = 10; // initial pin to enable Z stepper motor
int Camera_pin = 15;// connected to camera remote shutter
int Pre_focus_pin = 16;// connected to camera remote prefocus
int Flash_pin = 17;// connects to flash socket - rename and initialise if using more than one flash - ie Flash_2_pin = 19
int Motor_selected = 3; //start with Z motor selected
int Number_Photos_hold;
int Direction_hold;
int Distance_hold;
int Delay_1_hold;
int Delay_2_hold;
int Delay_shutter_lag = 100; // sets period required to activate camera
byte Reuse_Z_values;
byte Button_flag; // flag for button press
byte Old_button_flag = HIGH; // carry old value of button forward
String Main_Menu_Title = " --MAIN MENU-- ";
// 12345678901234567890
String Option_1 = " Stack ";
String Option_2 = " Jog ";
String Option_3 = " Rotate ";
String Option_4 = " Shoot ";
String Option_5 = " Flash ";
String Option_6 = " Shoot & flash ";
String Option_7 = " Motor - X,Y,Z,A,B ";
String Option_8 = "Distance multiplier ";
String Explain_1 = " (Create Z stack) ";
String Explain_2 = " (Jog back/forward)";
String Explain_3 = " (Control A,B Axes)";
String Explain_4 = " (Fire w/out flash)";
String Explain_5 = " (Fire flash) ";
String Explain_6 = " (Fire and flash) ";
String Explain_7 = " (Select motor) ";
String Explain_8 = "(Click sensitivity)";
LiquidCrystal_I2C lcd(0x3F, 20, 4); // set address for LCD on I2C
pinMode(10, OUTPUT);// set all motor enable pins as outputs
pinMode(20, OUTPUT);
pinMode(23, OUTPUT);
pinMode(29, OUTPUT);
pinMode(32, OUTPUT);
digitalWrite(10, HIGH); // set all motor enable pins to off = HIGH
digitalWrite(20, HIGH);
digitalWrite(23, HIGH);
digitalWrite(29, HIGH);
digitalWrite(32, HIGH);
pinMode(15, OUTPUT);//configure current flash and camera pins as outputs
pinMode(16, OUTPUT);
pinMode(17, OUTPUT);
pinMode(18, OUTPUT);
// others as one wishes
pinMode (Button_pin, INPUT_PULLUP);
//lcd.init();
lcd.clear();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print(" M A D B O F F I N ");
lcd.setCursor(0, 1);
lcd.print(" L A B S ");
lcd.setCursor(0, 2);
lcd.print("Software version 1.4");
lcd.setCursor(0, 3);
lcd.print(" 20th May 2017 ");
delay(4000);
lcd.clear();
lcd.print(Main_Menu_Title);
int k = encode_return(Upper_limit, Lower_limit); // call subroutine with upper and lower limits, k holds value returned from encoder
// Spell out menu options using encoder to select
switch (k) {
case 1:
lcd.print(Option_1);
lcd.print(Explain_1);
case 2:
lcd.print(Option_2);
lcd.print(Explain_2);
case 3:
lcd.print(Option_3);
lcd.print(Explain_3);
case 4:
lcd.print(Option_4);
lcd.print(Explain_4);
case 5:
lcd.print(Option_5);
lcd.print(Explain_5);
case 6:
lcd.print(Option_6);
lcd.print(Explain_6);
case 7:
lcd.print(Option_7);
lcd.print(Explain_7);
case 8:
lcd.print(Option_8);
lcd.print(Explain_8);
default:
Button_flag = digitalRead(Button_pin);
if (Button_flag != Old_button_flag)
Old_button_flag = Button_flag;
delay(100);
if (Button_flag == LOW && k == 1)
stacker();
else if (Button_flag == LOW && k == 2)
jogger();
else if (Button_flag == LOW && k == 3)
rotate();
else if (Button_flag == LOW && k == 4)
shoot();
else if (Button_flag == LOW && k == 5)
flash();
else if (Button_flag == LOW && k == 6)
shoot_flash();
else if (Button_flag == LOW && k == 7)
select_motor();
else if (Button_flag == LOW && k == 8)
click_Increment();
// SUBROUTINE encode_return () is sent upper and lower limits and returns encoder_value
int encode_return (int Upper_limit, int Lower_limit) {
int new_encoder_value = -999;
int mult_enc;
new_encoder_value = myencoder.read();
new_encoder_value = new_encoder_value / 4; // because each click increases encoder value by 4
// now test to see if limits exceeded
if (new_encoder_value >= Upper_limit) {
new_encoder_value = Upper_limit;
mult_enc = (Upper_limit * 4); //not clear why "if" not blocking code here????? add a 2...take it out or not??!
myencoder.write(mult_enc);
if (new_encoder_value <= Lower_limit) {
new_encoder_value = Lower_limit;
mult_enc = (Lower_limit * 4) + 2; //add 2 to stop "if" blocking code
return new_encoder_value;
// SUBROUTINE stacker () creates a stack of photos
void stacker() {
Direction = 1;
Number_photos = 1;
Distance = 0;
Delay_1 = 0;
Delay_2 = 0;
byte Button_flag = HIGH;
if (Motor_selected > 3)
lcd.clear();
// 01234567890123456789
lcd.print("--------------------");
lcd.print("Use X, Y or Z motor ");
lcd.print("Choose when offered!");
delay(1500);
lcd.clear();
select_motor();
lcd.clear();
lcd.print("--STACKER SUB-MENU--");
// do while loop here for direction to run
lcd.print(" (Direction) ");
if (Reuse_Z_values == HIGH)
myencoder.write(Direction_hold * 4);
do
Direction = encode_return(2, 1);
if (Direction == 1)
lcd.print(" Forward ");
if (Direction == 2)
lcd.print(" Reverse ");
delay(30);
} while (Button_flag == HIGH);
Direction_hold = Direction;
myencoder.write(4); // return to a value of 1 for encoder - divide by four!
delay(200); // inserting this delay ends problems with 'bouncing by' setting number of photos
// do while loop here for number of photos
Button_flag = HIGH;
lcd.print(" Number of Photos: ");
lcd.print(" ");
myencoder.write(Number_Photos_hold * 4);
do
Number_photos = encode_return(1000, 1);
lcd.setCursor(10, 2);
lcd.print(Number_photos);
lcd.print(" ");
delay(30);
Number_Photos_hold = Number_photos;
delay(200); // inserting this delay ends problems with 'bouncing by' setting distance to run
// do while loop here for distance to run
lcd.print(" Distance (um): ");
myencoder.write(Distance_hold * 4);
do
Distance = encode_return(10000, 1); // um could be a problem for longer distances!!
Distance = Distance * Increment;
//lcd.print(" ");
lcd.setCursor(9, 2);
lcd.print(Distance);
lcd.print(" ");
delay(30);
Distance_hold = Distance / Increment;
myencoder.write(4);
// do while loop here for delay to settle rail
lcd.print("Delay - settle (ms):");
myencoder.write(Delay_1_hold * 4);
do
Delay_1 = encode_return(9999, 1);
Delay_1 = Delay_1 * Increment;
lcd.print(Delay_1);
lcd.print(" ");
delay(30);
Delay_1_hold = Delay_1 / Increment;
// do while loop here for delay for exposure i.e. after tripping shutter
lcd.print("Delay - expose (ms):");
myencoder.write(Delay_2_hold * 4);
do
Delay_2 = encode_return(9999, 1);
Delay_2 = Delay_2 * Increment;
lcd.print(Delay_2);
lcd.print(" ");
delay(30);
Delay_2_hold = Delay_2 / Increment;
lcd.clear();
lcd.print("Photos: ");
lcd.print("Distance: ");
lcd.print("Delay (settle): ");
lcd.print(Delay_1);
lcd.print("Delay (expose): ");
lcd.print(Delay_2);
delay(2000);
lcd.clear();
lcd.print(" ACCEPT VALUES? ");
lcd.print("Press in 2 sec = YES");
Button_flag = HIGH;
for (int i = 0; i <= 1000; i++) {
delay(20);
if (Button_flag == LOW)
motor_driver();
lcd.clear();
lcd.print(" Finished Z stack! ");
delay(2000);
lcd.clear();
lcd.print("REUSE STACK VALUES? ");
Reuse_Z_values = LOW;
Button_flag = HIGH;
for (int i = 0; i <= 200; i++) {
delay(20);
i = 1;
do {// not at all clear why a for loop will not work...but it doesn't!
digitalWrite(Dir_pin, HIGH);
digitalWrite(Drive_pin, HIGH);
delayMicroseconds(600);
digitalWrite(Drive_pin, LOW);
i = i + 1;
} while (i <= step_size);
if (j < old_encoder_value)
i = 1;
do {
digitalWrite(Dir_pin, LOW);
i = i + 1;
old_encoder_value = myencoder.read();
if (Old_button_flag != Button_flag)
delay(70);
lcd.clear();
digitalWrite(Enable_pin, HIGH);
myencoder.write(4);
// SUBROUTINE rotate () rotates a rotary axis motor
void rotate () {
//probably needs to check that a rotary axis motor has been selected in the 'select motor' subroutine
//and then gets instructions re: clockwise or anticlockwise and the number of degrees (limits?)
int turn_clock = 0;
int turn_clock_old = 0;
if (Motor_selected <= 3)
lcd.clear();
lcd.print(" Use A or B motor ");
delay(1500);
lcd.clear();
select_motor();
Button_flag = HIGH;
pinMode (Dir_pin, OUTPUT);
pinMode(Drive_pin, OUTPUT);
pinMode(Enable_pin, OUTPUT);
digitalWrite(Enable_pin, LOW); // been problem when I defined enable pin as output?????
lcd.clear();
lcd.print("--ROTATE SUB-MENU---");
lcd.print("Jog step 0.22 degree");
lcd.print("Degrees of rotation:");
myencoder.write(0); // cahnged to zero -ok??
do
turn_clock = myencoder.read();
turn_clock = turn_clock / 4;
if (turn_clock > turn_clock_old) {
digitalWrite(Drive_pin , HIGH);
delayMicroseconds(900);
else if (turn_clock < turn_clock_old) {
turn_clock_old = turn_clock;
lcd.setCursor(8, 3);
lcd.print(float(turn_clock) * 0.225);
lcd.print(" ");
delay(100);
myencoder.write(4);
lcd.clear();
// SUBROUTINE shoot () takes a picture without flash, just fires shutter on press of rotary encoder knob
void shoot () {
// just fires shutter on press of rotary encoder knob
int k;
int j;
lcd.clear();
lcd.print("---SHOOT SUB-MENU---");
lcd.print("Click to take photo!");
// need to get clockwise or anticlockwise and degrees
delay(30);
digitalWrite(Pre_focus_pin, HIGH);
digitalWrite(Camera_pin, HIGH);
delay(Delay_shutter_lag);// no need for lag here
digitalWrite(Pre_focus_pin, LOW);
digitalWrite(Camera_pin, LOW);
delay(Delay_2);
lcd.print(" Photo taken! ");
lcd.clear();
return;
// SUBROUTINE flash () just fires the flashes on press of rotary encoder knob
void flash () {
// just fires flashes on press of rotary encoder knob
int k;
int j;
lcd.clear();
lcd.print("---FLASH SUB-MENU---");
lcd.print("Click to fire flash ");
delay(30);
digitalWrite(Flash_pin, HIGH);
delay(10);
digitalWrite(Flash_pin, LOW);
delay(Delay_2);
lcd.print(" Flash fired! ");
lcd.clear();
return;
// SUBROUTINE shoot_flash () just takes a single picture with flash on press of rotary encoder knob
// this and the routines shoot() & shoot_flash() could all be choices within one subroutine??
void shoot_flash () {
int k;
int j;
lcd.clear();
lcd.print("SHOOT&FLASH SUB-MENU");
lcd.print("Click = flash photo ");
delay(30);
delay(10);
delay(Delay_2);
lcd.print(" Flash photo taken!");
lcd.clear();
return;
// SUBROUTINE select_motor() allows choice of which motor to control
int select_motor () {
char motor = 'Z';
Button_flag = HIGH;
myencoder.write(12);
lcd.clear();
lcd.print("---MOTOR SUB-MENU---");
lcd.print(" A, B for rotations!");
lcd.print("Current motor: ");
lcd.print(motor);
Motor_selected = encode_return(5, 1);
switch (Motor_selected) {
case 1:
motor = 'X';
case 2:
motor = 'Y';
case 3:
motor = 'Z';
case 4:
motor = 'A';
case 5:
motor = 'B';
default:
lcd.print(" Current motor: ");
lcd.print(motor);
delay(70);
switch (motor) { //set pins up for the motor selected
case 'X':
Enable_pin = 20;
Dir_pin = 21;
Drive_pin = 22;
case 'Y':
Enable_pin = 23;
Dir_pin = 24;
Drive_pin = 25;
case 'Z': // reset these to 26, 27, 28 when rewiring done!
Enable_pin = 10;
Dir_pin = 11;
Drive_pin = 12;
case 'A':
Enable_pin = 29;
Dir_pin = 30;
Drive_pin = 31;
case 'B':
Enable_pin = 32;
Dir_pin = 33;
Drive_pin = 34;
default:
myencoder.write(4);
//return; //Motor_selected......no need to return this variable it's global
// SUBROUTINE click_Increment() adjusts the 'sensitivity' of the rotary encoder making
// it easier to dial up big numbers
int click_Increment() {
myencoder.write(40);
lcd.clear();
lcd.print("-CLICK INC SUB-MENU-");
lcd.print(" For each encoder ");
lcd.print(" click inc will be: ");
Increment = encode_return(50, 1);
lcd.setCursor(9, 3);
lcd.print(Increment);
// 1234567890
lcd.print(" ");
delay(100);
lcd.clear();
myencoder.write(4); // return encoder value to 1
return Increment;
this is all of it also is it possible to cut it down a bit? i am using an arduino mega to load this on
albert :o
Code must be inserted using the appropriate tag, in the editor it is the topleft icon like this </>. Select code and push the icon.
The code you posted seems to have errors at the beginning, try to erase all lines until
Here
I found a source but is not updated. Anyway there are not the lines I told you to erase.
bigal999:
Then attach the code.
Ow. My poor sore scrolling thumb
For a long program please just attach the .ino file. I have no intention of trying to join pieces together with the possibility that I introduce mistakes in the process.
See How to use the Forum
...R
bigal999
Code has errors and it is the same on the blog post.
In your post there is not jogger() function declaration.
In blog code post it is the same (you can read on the comments that others have the same error), the code is present but commented.
// /// SUBROUTINE jogger() jogs a motor via encoder // void jogger () { long int j = 0; int i = 0; int old_encoder_value; int step_size = 10; float jog_Increment = 0; Old_button_flag = HIGH; Button_flag = HIGH; if (Motor_selected > 3)
Edit: Much better that you attach the file that Peter emailed to you.
There is almost a formatting error in blog post.
hi here is the attached code in the right format
hope you can help
albert
Control_box_beta_version_1b_experimental.ino (28.9 KB)
That's the correct format but why are the #includes repeated 4 times at the start?
And it is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. Just use cstrings - char arrays terminated with 0.
Can you explain what the different parts of the program are intended to do? Trying to figure that out from reading the code can be very time consuming.
Is there a particular part of the program that is causing you trouble - to narrow down the part we need to study?
...R
the program can control 3 stepper motors i am only worried about one for now
a video of it working and explanation is here
has this helped
albert
My internet connection is too slow to view Youtube now. I might try in the morning.
OK, so you are just interested in one motor - but you have not said which one, or which part of the program controls it.
...R
Hi robin thank you for helping yes I only need 1 stepper motor. I think the bit of code is where you select the X y or z motor I would prefer to use the y one.
As to where in the code. It is I am unsure
Albert
