Folder locations of three Arduino library places
At the end of https://www.arduino.cc/en/Guide/Libraries its states:
Please note: Arduino libraries are managed in three different places: inside the IDE installation folder, inside the core folder and in the libraries folder inside your sketchbook
In Arduino IDE; under File - Preferences - Settings there is a field called "Sketchbook location"
There is a folder within Sketchbook location folder called "libraries" which I believe is "the libraries folder inside your sketchbook."
On Ubuntu; how do I find the path of IDE installation folder and the core folder?
Thanks
brentgracey:
Correct.
brentgracey:
I'm not sure. If you downloaded the official Arduino IDE from https://www.arduino.cc/en/Main/Software, then it's wherever you extracted the downloaded archive to.
If you used a package manager, then I guess you would have to research to see where it puts things.
brentgracey:
Here's a trick you can use to easily get there:
  • Select a board from the hardware package you want to find from the Tools > Board menu
  • File > Examples > SPI > BarometricPressureSensor (or any other SPI example sketch)
  • Sketch > Show Sketch Folder
  • Move up folder levels until you reach the one that contains boards.txt
You should also note that if you enable verbose output during compilation in the Arduino IDE's File > Preferences and then compile a sketch that uses libraries, the path of the libraries will be shown in the output in the black console pane at the bottom of the Arduino IDE window.
Fantastic; thank you for that detailed response; exactly the info I was looking for!!
You're welcome. I'm glad if I was able to be of assistance. Enjoy!
Per
