For just one sensor just check if the bottom float sensor low or high - up or down.
/*-----( Setup function )-----*/
pinMode(8, INPUT_PULLUP);
/*-----( Loop function )-----*/
boolean run_cycle = true;
const int lowerSersor = digitalRead(8); // lower float sensor on digital pin 8
if (lowerSersor == LOW) { // float sensor has dropped down - tank empty
// Toggle on
if (run_cycle) {
sendSMS();
run_cycle = false;
if (lowerSensor == HIGH) { // tank now full
// Toggle off
if (run_cycle == false) {
run_cycle = true;
void sendSMS() {
// Some code here to send a sms
Serial.println("AT");
Serial.println("AT+CMGF=1"); // send SMS in text mode
Serial.println("AT+CMGS=\"+01XXXX\""); //CHANGE TO Number , you'd like to receive message
Serial.print("Water level is low in underground tank (attention required)"); // content of the message
Serial.write(26); // ctrl+z ASCII code
