Folks, I am new to Arduino. Need help to automate water tank (water quantity)
Hello
Based on the below code how to connect the sensor to microprocessor
-----( Setup function )-----/
pinMode(8, INPUT_PULLUP);
/-----( Loop function )-----/
boolean run_cycle = true;
const int lowerSersor = digitalRead(8); // lower float sensor on digital pin 8
if (lowerSersor == LOW) { // float sensor has dropped down - tank empty
// Toggle on
if (run_cycle) {
sendSMS();
run_cycle = false;
if (lowerSensor == HIGH) { // tank now full
// Toggle off
if (run_cycle == false) {
run_cycle = true;
void sendSMS() {
// Some code here to send a sms
Serial.println("AT");
Serial.println("AT+CMGF=1"); // send SMS in text mode
Serial.println("AT+CMGS="+01XXXX""); //CHANGE TO Number , you'd like to receive message
Serial.print("Water level is low in underground tank (attention required)"); // content of the message
Serial.write(26); // ctrl+z ASCII code
Please add code tags when posting code (the </> button in the editor) as there are smileys in the code.
Anyway based on what I can read: sensor is expected to connect to pin 8, and just acts like a regular switch, active LOW.
Hello..
when i copy past the code to UNO it give me following error
Arduino: 1.8.4 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/Omair/Downloads/F1ILXY7IDIN9JKB/F1ILXY7IDIN9JKB.ino: In function 'void loop()':
F1ILXY7IDIN9JKB:15: error: 'sendSMS' was not declared in this scope
sendSMS();
F1ILXY7IDIN9JKB:19: error: 'lowerSensor' was not declared in this scope
/Users/Omair/Downloads/F1ILXY7IDIN9JKB/F1ILXY7IDIN9JKB.ino: In function 'void setup()':
F1ILXY7IDIN9JKB:33: error: redefinition of 'void setup()'
/Users/Omair/Downloads/F1ILXY7IDIN9JKB/F1ILXY7IDIN9JKB.ino:2:6: note: 'void setup()' previously defined here
F1ILXY7IDIN9JKB:41: error: redefinition of 'void loop()'
/Users/Omair/Downloads/F1ILXY7IDIN9JKB/F1ILXY7IDIN9JKB.ino:8:6: note: 'void loop()' previously defined here
exit status 1
option enabled in File -> Preferences.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Hello.
Somehow I am not able to see this <> in the editor.
Hello... Need some help Getting error message when verifying the code.
Error message attached as attachment.
/*-----( Setup function )-----*/
/*-----( Loop function )-----*/
    // Toggle on
    if (run_cycle) {
      sendSMS();
      run_cycle = false;
    // Toggle off
      run_cycle = true;
//ERFINDER CODE
#include <SoftwareSerial.h>
SoftwareSerial mySerial(9, 10);
  mySerial.begin(9600);   // Setting the baud rate of GSM Module
  Serial.begin(9600);    // Setting the baud rate of Serial Monitor (Arduino)
  delay(100);
  if (Serial.available()>0)
   switch(Serial.read())
    case 's':
      SendMessage();
    case 'r':
      RecieveMessage();
 if (mySerial.available()>0)
   Serial.write(mySerial.read());
 void SendMessage()
  mySerial.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
  delay(1000);  // Delay of 1000 milli seconds or 1 second
  mySerial.println("AT+CMGS=\"+923400008550\"\r"); // Replace x with mobile number
  mySerial.println("I am SMS from GSM Module");// The SMS text you want to send
  delay(100);
   mySerial.println((char)26);// ASCII code of CTRL+Z
 void RecieveMessage()
  mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to recieve a live SMS
The error message:
'sendSMS()' was not declared in this scope.
True.
Maybe you forgot to write that function?
Hello Edison.
Still it is giving me error.
