Following a Power Request - issue with the analog read function
Hi All,
I am doing a control for power electronics for an LC converter with two signal 50 % duty and in anti-phase. Basically I would like to change the frequency based on the power request.
#include <avr/io.h>
int Frequency = 200;
int DeadTime = 10;
int DutyCycle_A = (Frequency+DeadTime)/2;
int DutyCycle_B = (Frequency-DeadTime)/2;
int ledOut = 13;
volatile int state = LOW;
int voltage_pin = A0;
int current_pin = A1;
int temp_pin = A2;
int val_voltage = 0;
int val_current = 0;
int val_temperature = 0;
int acquisition_inverval = 126;
int j = 0;
int j_max =4;
int i=0;
int i_max=100;
int zerocrossing = 12;
int realPower= 0;
int Power_req = 2000;
void InitPortAnalog(void){
    pinMode(voltage_pin,INPUT);
    pinMode(current_pin,INPUT);
    pinMode(temp_pin,INPUT);
    pinMode(zerocrossing,INPUT);
void Interrupt(void){                                 // Set up the digital pin 2 to an Interrupt and Pin 4 to an Output
pinMode(ledOut, OUTPUT);
    SREG |= 0x80;                                   // Enable the interrupt SPI Control Register
    EICRA  = (1 << ISC00) | (1 << ISC10);          // Any change INT0, INT1
    EIMSK  = (1 << INT0) | (1 << INT1);            // External Interrupt Mask Register
    EIFR |= (1 << INTF0) | (1 << INTF1);
void InitTimer0(void){
    TCCR0A|= (1 << WGM01);                    // This set the timer zero in CTC
    OCR0A=acquisition_inverval;               //set CTC value - Top of Timer0- Here is stored the time interval between each acquisition
    TIMSK0 |= (1<<OCIE0A);                    // This generates the interrupt and the TOP
void InitPort(void)
    DDRB|=(1<<PORTB1)|(1<<PORTB2);                //Init PB1/OC1A and PB2/OC1B pins as output
void InitTimer1(void){
    TCNT1=0;                                    //Set Initial Timer value
                                                //set non inverted PWM on OC1A pin and inverted on OC1B
    TCCR1A|=(1<<COM1A1)|(1<<COM1B1)|(1<<COM1B0);
                                                             //set top value to ICR1
                                                //set corrcet phase and frequency PWM mode
    TCCR1B|=(1<<WGM13);
                                                //set compare values
    OCR1A=DutyCycle_B;                         //OCR1A=0x0064; half of ICR1=0x00FF
    OCR1B=DutyCycle_A;                         // OCR1B=0x0096; half of ICR1=0x00FF
void StartTimer0(void){                         //Start timer0 without no prescaller
   TCCR0B |= (1 << CS02);                    // this set the prescal at clock/8
void StartTimer1(void){                         //Start timer1 without no prescaller
    TCCR1B|=(1<<CS10);
int main(void){
    InitPortAnalog();
    Interrupt();
    InitPort();
    InitTimer1();
    InitTimer0();
    StartTimer1();
    StartTimer0();
    while(1)
        ICR1=Frequency;                             //0x00FF equivale a 255
       realPower=0;
                for( j=0;j<j_max;j++){        // This for is meant in order to avg the power along 4 semicycle
                if (digitalRead(zerocrossing)==1){
                                                  int val_voltage_act=0;
                                                  int val_current_act=0;
                                                  for( i=0;i<i_max;i++){                                                 // Using for loop to calculate average power
        val_voltage_act = (analogRead(voltage_pin)/2.56); // 2.56 is the ratio between the real value and the acquired  one
        val_voltage += val_voltage_act*val_voltage_act;
        val_current_act = (analogRead(current_pin)/29.25);        // 29.25 is the ration between the real value and the acquired  one
        val_current += val_current_act*val_current_act;
        delayMicroseconds(100);
        realPower = 0.1*sqrt(val_voltage/i_max)*sqrt(val_current/i_max);
                                         realPower += realPower;
                                         realPower = .25*realPower;
          if (analogRead(realPower >Power_req)){
                                                  Frequency++ ;
                                                  } else if (realPower <Power_req){
                                                 Frequency-- ;
ISR(TIMER0_COMPA_vect){
    state = !state;
    digitalWrite(ledOut, state);
ISR(INT0_vect)
{     //syncronization of the analog reading with the zero crossing
  OCR0A=0;
  TIFR0=0;
ISR(INT1_vect)
{                                        //If the Interrupt on the PIN 1 is trigger all the Control signals go to 0
    digitalWrite(10, LOW);
    digitalWrite(9, LOW);
but I checked the analogRead and the control does not acquire anything. Someone can check the code?
Thank you very much
Regards,
Vittorio
Can you please edit your posting to use code tags?
Here the last release, but still the Analog Read does not work
#include <avr/io.h>
int DeadTime = 10;
int ledOut = 13;                                    // The output LED pin
volatile int state = LOW;                          // The input state toggle
int voltage_pin = A0;                               // This pin is the voltage sensing of the bus capacitor
int current_pin = A1;                               // This pin is the input current sensing
int temp_pin = A2;                                  // This pin is the temperature sensing
int val_voltage = 0;                               // variable for storing the voltage
int val_current = 0;                               // variable for storing the current
int val_temperature = 0;                          // variable for storing the temperature
int acquisition_inverval = 126;                   // Acquisition interval
int j = 0;
int j_max =4;
int i=0;
int i_max=100;
float realPower= 0;
int Power_req = 0;
    pinMode(voltage_pin,INPUT);                     //Set voltage as input pin
    pinMode(current_pin,INPUT);                     //Set current as input pin
    pinMode(temp_pin,INPUT);                        //Set voltage as input pin
    pinMode(zerocrossing,INPUT);                    //Set voltage as input pin
void InitPort(void)
    TCCR1B|=(1<<WGM13);
    TCCR1B|=(1<<CS10);
int main(void){
    InitPortAnalog();
    Interrupt();
    InitPort();
    InitTimer1();
    InitTimer0();
    StartTimer1();
    StartTimer0();
    while(1)
       realPower=0;
                                                  float val_voltage_act=0;
                                                  float val_current_act=0;
          if (analogRead(val_temperature > 620)){
                                                  Frequency++ ;
                                                  Frequency++ ;
        Frequency-- ;
    state = !state;
ISR(INT0_vect)
  OCR0A=0;
  TIFR0=0;
ISR(INT1_vect)
