Following Robot
Hello, I have already built my robot using the Arduino Mega along with 2 L298N motor controllers and a bluetooth module.
Also, I am able to control the movement of my robot using bluetooth though my mobile phone.
May I know if there is any way to continue this project so that the robot with the bluetooth module to follow my mobile phone? Thank you!
Might find some hints here;
Following Robot
srnet:
Following Robot
Yes I did. But most of them are follow user using sensors, not mobile phone using bluetooth.
Bluetooth gives no directional information
Here's something:
If I got it right, the HC-05 Bluetooth module can give you the strength of the Bluetooth signal. You could perhaps use something that isolates the signal, like placing the module inside a tube of lead and hope to get a significant raise in the signal strength, when you rotate the tube towards the phone.
A directional antenna (I'm sure it's possible to build one for the Bluetooth frequency - make it look a bit steampunky and you have yourself a nice little radar) indeed can give a direction, but no distance. You need that, too.
But is Bluetooth even usable as beacon? Does it transmit all the time or at least very frequently?
