I am making a GPS tracker using Arduino Uno and a Adafruit FONA808 shield.
I want it to text me the GPS latitude and longitude, however it sends the the text ‘webaddress,latitude,longitude’ instead of the values.
Please Help.
Kindest Regards,
Denis
Here is my code below.
#include "Adafruit_FONA.h"
// standard pins for the shield, adjust as necessary
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
// HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
// Have a FONA 3G? use this object type instead
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
while (! Serial);
Serial.println(F("Adafruit FONA 808 & 3G GPS demo"));
Serial.println(F("Initializing FONA... (May take a few seconds)"));
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while(1);
Serial.println(F("FONA is OK"));
// Try to enable GPRS
Serial.println(F("Enabling GPS..."));
fona.enableGPS(true);
delay(2000);
float latitude, longitude, speed_kph, heading, speed_mph, altitude;
// if you ask for an altitude reading, getGPS will return false if there isn't a 3D fix
boolean gps_success = fona.getGPS(&latitude, &longitude, &speed_kph, &heading, &altitude);
char webaddress [] = ("https://www.google.com/maps/place/");
char sendto[21] = "my phone number";
char message[141] = "webaddress,latitude,longitude";
if (gps_success) {
Serial.print("GPS lat:");
Serial.println(latitude, 6);
Serial.print("GPS long:");
Serial.println(longitude, 6);
Serial.print("GPS speed KPH:");
Serial.println(speed_kph);
Serial.print("GPS speed MPH:");
speed_mph = speed_kph * 0.621371192;
Serial.println(speed_mph);
Serial.print("GPS heading:");
Serial.println(heading);
Serial.print("GPS altitude:");
Serial.println(altitude);
Serial.println(message);
if (!fona.sendSMS(sendto,message)) {
Serial.println(F("Failed"));
Serial.println(F("Sent!"));
delay(600000);
Serial.println("Waiting for FONA GPS 3D fix...");
// Fona 3G doesnt have GPRSlocation :/
if ((fona.type() == FONA3G_A) || (fona.type() == FONA3G_E))
return;
// Check for network, then GPRS
Serial.println(F("Checking for Cell network..."));
if (fona.getNetworkStatus() == 1) {
// network & GPRS? Great! Print out the GSM location to compare
boolean gsmloc_success = fona.getGSMLoc(&latitude, &longitude);
if (gsmloc_success) {
Serial.print("GSMLoc lat:");
Serial.print("GSMLoc long:");
Serial.println("GSM location failed...");
Serial.println(F("Disabling GPRS"));
fona.enableGPRS(false);
Serial.println(F("Enabling GPRS"));
if (!fona.enableGPRS(true)) {
Serial.println(F("Failed to turn GPRS on"));
