FONA808 and nRF52 Feather
Hi all,
I have a problem running Adafruit FONA808 breakout with Adafruit nRF52840 Feather without a USB connection (with USB all works as intended). All running on arduino sketch based on the examples provided by adafruit.
I have tried a few things, with running a SoftwareSerial communication through connecting RX/TX pins of FONA to A0/A1.
The last thing I have tries is to run through HardwareSerial connecting RX/TX pins of FONA to physical RX/TX pins of nRF52840 Feather.
No luck so far… Seems like no communication. I will post the code that runs in this situation, please advise what could be done, I hit the wall.
#include <Adafruit_FONA.h>
#include <ArduinoJson.h>
#include <bluefruit.h>
// #define FONA_RX A0
// #define FONA_TX A1
#define FONA_RST 9
// this is a large buffer for replies
char replybuffer[255];
// software serial to communicate with FONA
// #include <SoftwareSerial.h>
// SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
// SoftwareSerial *fonaSerial = &fonaSS;
HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
  while ( !Serial ) delay(10);
  fonaSerial->begin(4800);
  type = fona.type();
  fona.enableGPS(true);
  fona.enableGPRS(true);
  delay(10000);
  if (fona.getNetworkStatus() ==1 ) {
    char gpsdata[120];
    int8_t stat;
    uint8_t fr = fona.getRSSI();
    int8_t r;
    uint16_t vbat;
    uint16_t percbat;
    if (fr == 0) r = -115;
    if (fr == 1) r = -111;
    if (fr == 31) r = -52;
    if ((fr >= 2) && (fr <= 30)) {
      r = map(fr, 2, 30, -110, -54);
    stat = fona.GPSstatus();
    if (stat > 1) {
      fona.getGPS(0, gpsdata, 120);
      fona.getBattVoltage(&vbat);
      fona.getBattPercent(&percbat);
      //Post data HTTP
      uint16_t statuscode;
      int16_t length;
      char c;
      char url[80] = "someurl.com";
      char data[300];
      const size_t capacity = JSON_OBJECT_SIZE(20);
      DynamicJsonDocument doc(capacity);
      doc["vbat"] = vbat;
      doc["percbat"] = percbat;
      doc["r"] = r;
      doc["stat"] = stat;
      doc["gpsdata"] = gpsdata;
      serializeJson(doc, data);
      fona.HTTP_POST_start(url, F("text/plain"), (uint8_t *) data, strlen(data), &statuscode, (uint16_t *)&length);
      while (length > 0) {
        a = length;
        while (fona.available()) {
          c = fona.read();
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
          loop_until_bit_is_set(UCSR0A, UDRE0); /* Wait until data register empty. */
          UDR0 = c;
#else
          //Serial.write(c);
#endif
          length--;
            if (! length) break;
      fona.HTTP_POST_end();
      // TO DO
      //Serial.println("No FIX");
    // TO DO
    fona.enableGPRS(false);
    delay(60000);
