Fonction RC_Reader() appelée par une interruption
Bonsoir,
Dans la lecture des voies d’un récepteur, je souhaite remplacer l’appel de la procédure RC_Reader() qui était faite dans la fonction loop() par une interruption.
Ceci est motivé par des boucles de traitement un peu longues dans le programme final et un besoin d’avoir des valeurs fraiches.
Dans le programme tel que vous l’avez ci-dessous, la procédure RC_Reader() n’est appelée qu’une seule fois puis plus rien!
http://playground.arduino.cc/Code/ReadReceiver
Copyright 2011 Lex Talionis (Lex.V.Talionis at gmail)
This program is free software: you can redistribute it
and/or modify it under the terms of the GNU General Public
License as published by the Free Software Foundation,
either version 3 of the License, or (at your option) any
later version.
This code uses pin change interrupts and timer 1 to mesure the
time between the rise and fall of 3 channels of PPM
(Though often called PWM, see http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1253149521/all)
on a typical RC car reciver.  It could be extended to as
many channels as you like.  It uses the PinChangeInt library
to notice when the signal pin goes high and low, and the
Timer1 library to record the time between.
#include <PinChangeInt.h>    // http://playground.arduino.cc/Main/PinChangeInt
#include <PinChangeIntConfig.h>
#include <TimerOne.h>        // http://playground.arduino.cc/Code/Timer1
#include <MsTimer2.h> // inclusion de la librairie Timer2
//#define NO_PORTB_PINCHANGES //PinChangeInt setup
//#define NO_PORTC_PINCHANGES    //only port D pinchanges (see: http://playground.arduino.cc/Learning/Pins)
#define PIN_COUNT 4    //number of channels attached to the reciver
#define MAX_PIN_CHANGE_PINS PIN_COUNT
//arduino pins attached to the reciver
#define RC_Voie1 3
#define RC_Voie2 5
#define RC_Voie3 6
#define RC_Voie4 7
byte pin[] = {RC_Voie1, RC_Voie2, RC_Voie3, RC_Voie4};    //for maximum efficency thise pins should be attached
unsigned int time[] = {0,0,0,0};                // to the reciver's channels in the order listed here
byte state=0;
byte burp=0;    // a counter to see how many times the int has executed
byte cmd=0;     // a place to put our serial data
byte iRC=0;       // global counter for tracking what pin we are on
void flash() {
  static boolean output = HIGH;
  digitalWrite(13, output);
  output = !output;
    Serial.print("PinChangeInt ReciverReading test : ");
    Timer1.initialize(2200);    //longest pulse in PPM is usally 2.1 milliseconds,
                                //pick a period that gives you a little headroom.
    Timer1.stop();                //stop the counter
    Timer1.restart();            //set the clock to zero
    for (byte i=0; i<4; i++)
        pinMode(pin[i], INPUT);     //set the pin to input
        digitalWrite(pin[i], HIGH); //use the internal pullup resistor
    //PCintPort::attachInterrupt(pin[iRC], rise,RISING); // attach a PinChange Interrupt to our first pin
    PCintPort::attachInterrupt(RC_Voie1, rise,RISING); // attach a PinChange Interrupt to our first pin
// initialisation interruption Timer 2
//  MsTimer2::set(500, flash); // ça fonctionne la led clignotte
  MsTimer2::set(500, RC_Reader); // ne fonctionne pas
  MsTimer2::start(); // active Timer 2
    cmd=Serial.read();        //while you got some time gimme a systems report
    if (cmd=='p')
        Serial.print("time:\t");
        for (byte i=0; i<PIN_COUNT;i++)
            Serial.print(i,DEC);
            Serial.print(":");
            Serial.print(time[i],DEC);
            Serial.print("\t");
        Serial.print(burp, DEC);
    cmd=0;
    Serial.println(".");	// ça s'affiche
//    RC_Reader();  // Remplacé par un appel via une interruption
void RC_Reader(){
  Serial.println("|");
    switch (state)
        case RISING: //we have just seen a rising edge
            PCintPort::detachInterrupt(pin[iRC]);
            PCintPort::attachInterrupt(pin[iRC], fall, FALLING); //attach the falling end
            state=255;
        case FALLING: //we just saw a falling edge
            iRC++;                //move to the next pin
            iRC = iRC % PIN_COUNT;  //i ranges from 0 to PIN_COUNT
            state=255;
        /*default:
            //do nothing
            break;*/
    burp++;
void rise()        //on the rising edge of the currently intresting pin
    Timer1.restart();        //set our stopwatch to 0
    Timer1.start();            //and start it up
    state=RISING;
void fall()        //on the falling edge of the signal
    state=FALLING;
    time[iRC]=readTimer1();    // read the time since timer1 was restarted
//  time[i]=Timer1.read();    // The function below has been ported into the
                            // the latest TimerOne class, if you have the
                            // new Timer1 lib you can use this line instead
    Timer1.stop();
unsigned long readTimer1()        //returns the value of the timer in microseconds
{                                    //rember! phase and freq correct mode counts
                                    //up to ICR1 then down again
    unsigned int tmp=TCNT1;
    char scale=0;
    switch (Timer1.clockSelectBits)
    case 1:// no prescalse
        scale=0;
    case 2:// x8 prescale
        scale=3;
    case 3:// x64
        scale=6;
    case 4:// x256
        scale=8;
    case 5:// x1024
        scale=10;
    while (TCNT1==tmp) //if the timer has not ticked yet
        //do nothing -- max delay here is ~1023 cycles
    tmp = (  (TCNT1>tmp) ? (tmp) : (ICR1-TCNT1)+ICR1  );//if we are counting down add the top value
                                                        //to how far we have counted down
    return ((tmp*1000L)/(F_CPU /1000L))<<scale;
Toutes vos remarques sont les biens venues…
