Is there documentation on how to define a font in an .h file?
I know that it starts with Width, Height, First char, Number of chars, then a jump table followed by font data. But I don't understand the jump table nor the format of the font data.
Presumably you have a graphics library in mind to display the font. One approach is to examine the library documentation and/or code to determine what format it expects for font data.
There must be documentation on the file format. I read that it is Open Source, but I cannot find it.
If you look at one of the font files, you see that even a fixed pitch font is described as in my first post. But I cannot figure out how to create my own. It is not a simple array.
I am using a ESP32-LoRa board with an OLED. It is made by Heltec. It uses the library called "Heltec_ESP32_Dev-Boards".
Its documentation says: setFont sets the current font. Available default fonts: ArialMT_Plain_10, ArialMT_Plain_16, ArialMT_Plain_24. Or create one with the font tool at http://oleddisplay.squix.ch. Syntax: void setFont(const uint8_t fontData);*
If you go to the mentioned website, it will generate the code to put into a .h file defining a specific font. But I don't know how to make my own file. I want to make a font that they do not have.
Thank you, but I already have the library. I read all of the documentation that came with it. I even rewrote it in proper English so I could understand it. But the only mention of custom fonts is what I quoted in my earlier post. I read somewhere that the algorithm for creating the .h files is known. But I cannot find it.
Thank you John. Your link led me to the doc I was hoping for. It does not specifically describe the file format, but it gave me the tools needed to figure it out. Now I can use the font editor, or do it by myself.
