Font problem-oled display
Hello,
this is my code:
#include <OLED_I2C.h>
#include <SoftwareSerial.h>
int rxPin = 10;
int txPin = 14;
int secondi;
int minuti;
int ore;
int y = 23; //altezza 23 px per stampare a schermo
int x = 90; //centro schermo
String tot;
SoftwareSerial bluetooth(rxPin, txPin);
String message; //string that stores the incoming message
OLED  myOLED(SDA, SCL, 8);
extern uint8_t SmallFont[];
  Serial.begin(9600); //set baud rate
  bluetooth.begin(9600); //set baud rate
  myOLED.begin();
myOLED.setFont(SmallFont);
  randomSeed(analogRead(0));
  while (bluetooth.available()) {
    message += char(bluetooth.read());
  if (!bluetooth.available())
    if (message != "")
    { //se il dato è disponibile
     // Serial.println(message); //mostra il dato
       RicavaOrario(message);
      message = ""; //cancella il dato
 // myOLED.print("OLED_I2C Scrolling Text Demo ", 90, y);
 // myOLED.update();
 if(secondi<60)
  secondi++;
 if(secondi==60)
  secondi=0;
  minuti++;
 if(minuti==60)
  minuti=0;
  ore++;
 if(ore==24)
  ore=0;
  secondi=0;
  minuti=0;
 //myOLED.print(ore,':',minuti,':',secondi);
 tot=String(ore+String(":")+minuti+String(":")+secondi);
 Serial.println(tot);
  delay(1000); //delay
 Stampa(tot);
  void RicavaOrario(String msg)
    char Orestring[9]={msg[0],msg[1],msg[2],msg[3],msg[4],msg[5],msg[6],msg[7],NULL};
    char s[3]={msg[0],msg[1],NULL};
    char m[3]={msg[3],msg[4],NULL};
    char o[3]={msg[6],msg[7],NULL};
    secondi=atoi(s);
    minuti=atoi(m);
    ore=atoi(o);
  void Stampa(String a)
    myOLED.print(a, CENTER , y);
    myOLED.update();
The problem is this part:
I want to use the BigFont but when i try to change it into BigFont ,Arduino IDE says that there are some errors.
extern uint8_t BigFont[];
myOLED.setFont(BigFont);
The errors are :
-undefined reference to BigFont' -more undefined references to BigFont' follow
I tried to download some fonts from some sites and put them in the project folder but when I run the code i see that the font in the display has a lot of problems and it is
incomprehensible.
Any solutions?
Sorry if I misspelled some words,I'm from Italy.
I don't have the library, but it is possible that some fonts aren't defined for smaller processors.
Guys,
I really need to solve this problem.
I must change the font size
AWOL gave you the answer. Get a bigger processor. Uselessly whining that you must use some under-powered processor is a complete waste of our time (and yours).
