"foo does not exist as a name type"
I've got this code:
void setup() { // put your setup code here, to run once: // initialize digital pin LED_BUILTIN as an output. pinMode(LED_BUILTIN, OUTPUT); foo = 0; }
void loop() { // put your main code here, to run repeatedly: while(foo < 5){
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second var++; } };
It gives me the error message. what am I doing wrong? (yes I copied most of the blink program).
Where do you declare "foo"?
Please remember to use code tags when posting code.
(deleted)
AWOL: Where do you declare "foo"?
In the setup I put "foo = 0;"
How do I do the code tags?
TheTacticalCat: In the setup I put "foo = 0;"
And the type of "foo" is ... what?
Well, you managed quote tags.
spycatcher2k: foo only exists in setup()
Not even there, it's not declared.
You want this, above setup():
int foo=0; //or even byte
manor_royal: Not even there, it's not declared.
Thanks, Works now. Just needed int. C++ is way more harsh than python. :P
TheTacticalCat: Thanks, Works now. Just needed int. C++ is way more harsh than python. :P
Yeah, it's a stickler for making you give every variable a type before you use the! Also variable scope - it seems unnecessary and awkward at first but is actually quite useful once you get into it.
