Foosball Scoring
Hi I have a foosball table that I want the scoring to be electronic. I've figured out the schematic and some of the programing.
I used these 2 sites as references and followed their schematics:
http://www.thebox.myzen.co.uk/Hardware/Sneak_Thief.html
My code
int x=0; //used for for loopss
const int irPin = A0;
const int irPin2 = A1;
int value = 0; //the variables I use for counting
int value2 = 0;
int counter = 0;
int counter2 = 0;
int lastState = 0;
int lastState2 = 0;
  DDRD=0xff; // all pins 0-7 OUTPUTs
  DDRB=0xff; // all pins 8-13 OUTPUTs
  PORTD=0x00; // make pins 0-7 LOWs
  PORTB=0x00; // make pins 8-13 LOWs
  value = analogRead(irPin);
  value2 = analogRead(irPin2);
  if(counter < 1){
    turnOnSquare(3);
    displayDigit(0);
    delay(2);
    turnOnSquare(5);
    displayDigit(10);
    delay(2);
    turnOnSquare(2);
    displayDigit(0);
    delay(2);
    if(counter2 < 1){
      turnOnSquare(3);
      displayDigit(0);
      delay(2);
      turnOnSquare(5);
      displayDigit(10);
      delay(2);
      turnOnSquare(2);
      displayDigit(0);
      delay(2);
    if(value != lastState && value != lastState + 1) {
      if (value < 127 || value > 133) {
        counter++;
        Serial.println("on");
        Serial.print("points:  ");
        Serial.println(counter);
        Serial.println(value);
        turnOnSquare(3);
        displayDigit(counter);
        delay(50);
        if(counter >= 10){
          while(1){
            turnOnSquare(3);
            displayDigit(1);
            delay(2);
            turnOnSquare(4);
            displayDigit(0);
            delay(2);
            turnOnSquare(5);
            displayDigit(10);
        else {
          Serial.println("off");
      if(value2 != lastState2 && value2 != lastState2 + 1) {
        if (value2 < 127 || value2 > 133) {
          counter2++;
          Serial.println(counter2);
          Serial.println(value2);
          turnOnSquare(2);
          displayDigit(counter2);
          delay(50);
          if(counter2 >= 10){
            while(1){
              turnOnSquare(2);
              displayDigit(1);
              delay(2);
              turnOnSquare(1);
              displayDigit(0);
              delay(2);
              turnOnSquare(5);
              displayDigit(10);
          else {
        lastState = value;
        lastState2 = value2;
void turnOnSquare(int num)
  int d1=9,d2=10,d3=11,d4=12;
  switch(num)
  case 1:
    digitalWrite(d2,LOW);
    digitalWrite(d3,LOW);
    digitalWrite(d4,LOW);
    digitalWrite(d1,HIGH);
  case 2:
    digitalWrite(d1,LOW);
    digitalWrite(d2,HIGH);
  case 3:
    digitalWrite(d3,HIGH);
  case 4:
    digitalWrite(d4,HIGH);
  case 5:
    digitalWrite(d4,LOW); // this is so I can cleanly turn off the display
void displayDigit(int num)
  switch(num)
  case 0:
    PORTD=B00000011; // pins 2-7 on
    digitalWrite(8,HIGH); // turn off pin 8
  case 1:
    PORTD=B11100111; // only pins 2 and 3 are on
  case 2:
    PORTD=B10010011; // only pins 2,3,5 and 6 on
    digitalWrite(8,LOW); // segment g on
  case 3:
    PORTD=B11000011; // only pins 2,3,4 and 5 on
  case 4:
    PORTD=B01100111; // only pins 3,4 and 7 on
  case 5:
    PORTD=B01001011; //B10110100; // only pins 2,4,5 and 7 on
  case 6:
    PORTD=B00001011; //B11110100; // only pins 2,4,5,6 and 7 on
  case 7:
    PORTD=B11100011; // only pins 2,3 and 4 on
    digitalWrite(8,HIGH); // segment g off
  case 8:
    digitalWrite(8,LOW); // turn on pin 8
  case 9:
    PORTD=B01000011; // only pins 2,3, 4 and 5 on
  case 10:
    PORTD=B11111111;
    digitalWrite(8, HIGH);
    break; //tunr off every thing
Ok so what happens when I turn it on is it displays 0:0 then is I trip the first ir sensor it reads :1 I want it to read 0:1 and it wont keep counting from there. Also I cant get the first digit to count like the second. Oh and value2 is for the first number. The ir sensor for value2 works fine and so does the display so its a software problem. Please help.
I saw this:
int value2 = 0;
int counter = 0;
int counter2 = 0;
int lastState = 0;
int lastState2 = 0;
and I quit reading.
If you have a value2, it's counterpart is value1, not value.
  if(counter < 1){
    turnOnSquare(3);
    displayDigit(0);
    delay(2);
    turnOnSquare(5);
    displayDigit(10);
    delay(2);
    turnOnSquare(2);
    displayDigit(0);
    delay(2);
I don't know what to make of the magic numbers.
    if(counter2 < 1){
      turnOnSquare(3);
      displayDigit(0);
I don't understand why the value in counter2 is of interest only if counter(1) is 0 or negative.
I don't understand what counter(1) and counter2 are supposed to represent. Why does all this stuff with counter and turnOnSquare() and displayDigit() happen BEFORE the value(1) and value2 values are used?
Ok well sorry for the hassle, but in the time it took someone to respond I solved my problem. Thanks for the help anyway though.
