Guys, I have this problem. I think I could map the lines right (Check out the images), and yet I still can't get accurate values. I'm using a ESP32 and I'm only testing 1 sensor, let's say the number 2. It's linked to the ESP32 GPIO36 VP-Pin, as the simple code below shows.
The first VCC line is wired to the 3v3 pin. I wonder if I have to connect something to GND? I tried it already, but I got no Values. When I disconnect the GND from the GPIO36 VP-Pin I got some values but it's not constante. Sometimes it stuck at the maximum value: 4095.
Our problem is different. We have no clue about what you are using or how you have it all wired up and how you have it all powered. A drawing of how all is connected as well as data sheet links to the actual devices you are connecting would immediately help solve our problem.
Yes. Many of the pins appear to have no, or very poor connections to the pads, just a blob of solder on the protruding pin. Add flux to everything and resolder. Verify continuity with a multimeter.
The thing is: I am just trying the first 2. And yes, it needs to be improved. Continuity test is ok, everything is connected. Still the same errors / not working. Thanks, guys.
No, your connections are the problem. Every solder joint is a cold joint (wire was not at temperature and did not receive the solder, so the solder balled up and sits on top of the pin). When you "test" the joints, the pressure you apply causes continuity.
