Hello
I have on order
for (f =1, f <8, f++) {
//blablabla}
my question is stupid my f = 1 means that it puts f at 1 or that if f is equal to 1 it executes what is after
Hello
I have on order
//blablabla}
I thought you wanted eight iterations?
The reference page for the for loop is a.useful starting point for learning.
Why have you started another topic?
I ask the question for something else because its not working for me and from what I understand f = 1 means that it puts f equal to 1 puts like its not working I’m not sure
(I started arduino for less than 1 week)
ludocraft:
It sets f to 1
Many things in programming start at 0. For example the elements in a 4 element array are numbered 0 to 3
...R
2nd question as I do not know if it is necessary to create another subject
I have
for (f =7; f >1; f--){
Write_Max7219(f, 126);
delay(150);
It does not work normally it should do something like this
Write_Max7219(7, B01000010)
Write_Max7219(6, B01000010)
Write_Max7219(5, B01000010)
Write_Max7219(4, B01000010)
Write_Max7219(3, B01000010)
Write_Max7219(2, B01000010)
its not working its pass to what is after
eceque I made a mistake somewhere where it is normal ??
for is in an else if
the if part works well
I said nothing I was wrong between the first condition and the 2 nd Write_Max (f) had the same value on both is for its that I had the impression that its does nothing
Please post the complete program and also post a sample of the actual output.
...R
126 is not B01000010.
ludocraft:
//blablabla}
Since you used ‘,’ instead of the required ‘;’, and you commented out the closing ‘}’, your statement won’t compile. If you had done it correctly:
for (f = 1; f < 8; f++)
//blablabla
the result would be roughly equivalent to:
f = 1;
while (f < 8)
//blablabla
f++;
