Hey Guys,
I have an easy stepper program gig ready to go ASAP.
I want to push a momentary button to activate a stepper motor for a programmed number of seconds.
So push momentary button, stepper motor turns on for 5 seconds then stops.
I think you will have to program in the speed, accel+ decelerate etc, etc to accomplish that.
I want something like 1000 rpm. I can modify it after.
Also,may need a little help on how to wire up the motor and switch to the uno.
Motor
STP-MTRH-34127
SureStep stepper motor, NEMA 34 frame, IP40, single shaft, 6.3A, 1288 oz-in holding torque, 1.8-degree step angle, 200 steps per revolution, bipolar.
Driver
Leadshine DC advanced microstepping stepper drive, 7A per phase, 2-phase output, 24-70 VDC, bipolar, velocity and position mode, 200 to 12800 steps per revolution.
Power Supply
STP-PWR-4810
SureStep linear power supply, 48 VDC at 10A unregulated, 5 VDC at 0.5A regulated output, 10A, 480W, 120/240 VAC nominal input, switch selectable, 1-phase, anodized aluminum open frame, wall mount, screw terminals.
