For Loop and Serial.Print not working
Basically, when using a For loop, Serial.print is only printing at the end. Tried this on a Nano and a Mega. Using IDE 1.8.19.
From the code below, I get this in the serial monitor:
Hi
h: 4
k: 6
  Serial.print("\r\nHi");
  Read();
void Read()
  byte h;
  byte k = 6;
  for (h = 0; h < 4; h++);
    if (h == 2) k++;
    Serial.print("\r\n h: ");
    Serial.print(h);
    Serial.flush();
  Serial.print("\r\n k: ");
  Serial.print(k);
Welcome to the forum
What did you expect the code to print ?
a delay of few milliseconds might work.
loose the semi colon at the end of the for loop (you basically have an empty loop otherwise)
I knew it would be such a simple problem that I couldn't see it. Thanks.
