Aside from the useless emoticon, did you have something to say?
i inside
if (i > 3)
in for loop and result ditto.
Full my code
String SerialGET = "";
void loop(){
while (Serial.available()) {
char c = Serial.read();
if (c == '\n') {
/* You code chk */
Serial.println(SerialGET);
Serial.println(IPValid(SerialGET));
SerialGET = "";
}else
SerialGET += c;
bool IPValid(String IP){
int DotCount = 0;
int StartArr[4];
StartArr[0] = 0;
for (int i = 0; i < IP.length();) {
i = IP.indexOf('.', i);
if (i == -1)
i++;
StartArr[DotCount+1] = i;
DotCount++;
if (DotCount != 3)
return false;
if ((sizeof(StartArr)/sizeof(int)) - 1 > 3)
return false;
StartArr[4] = IP.length()+1;
bool Error = false;
for (int i=0;i<4;i++){
if (i > 3)
Serial.println("i: " + String(i));
String CutS = IP.substring(StartArr[i], StartArr[i+1]);
if (CutS.length() < 1)
return false;
return true;
return false;
This is pretty silly. The size of the array is fixed at compile time. Storing, or not, values in the array does not change the size of the array.
Equally silly. The array size is 4, meaning that the index values range from 0 to 3. Writing off the end of the array is NEVER a good idea.
if (i > 3)
More silliness. If you want the loop to iterate fewer times, change the while clause.
this my code problem is loop if. array set and size no problem.
if (i == -1)
i++;
You have totally lost me there. You have a for loop, and in the middle you are changing the loop index. And after that, well, I have no idea.
int StartArr[4];
There is no StartArr[4]. This probably overwrites some local stack variable, with unpredictable results.
Sure. Why not.
Hmm. Make it a while loop, perhaps?
You can probably make it work. It's not good design.
