for loop confusion
I have a for loop that is only cycling through once and I cannot figure out why. I think it might have to do with some of the returns. I modified this code from the example in the OneWire Library. I hope to be getting the average of five temperature readings every 5 seconds. Thank you for your help.
#include <OneWire.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire  ds(4);  // on pin 10 (a 4.7K resistor is necessary)
int x =0;
float fahrenheit[5];
void setup(void) {
void SoilTemp(){
  for(x=0; x<5; x++){
        byte i;
        byte present = 0;
        byte type_s;
        byte data[12];
        byte addr[8];
        float celsius;
        if ( !ds.search(addr)) {
          ds.reset_search();
          delay(250);
          return;
        if (OneWire::crc8(addr, 7) != addr[7]) {
            return;
         // the first ROM byte indicates which chip
        switch (addr[0]) {
          case 0x10:
            type_s = 1;
          case 0x28:
            type_s = 0;
          case 0x22:
            type_s = 0;
          default:
            return;
        ds.reset();
        ds.select(addr);
        ds.write(0x44, 1);        // start conversion, with parasite power on at the end
        delay(150);     // maybe 750ms is enough, maybe not
        present = ds.reset();
        ds.select(addr);
        ds.write(0xBE);         // Read Scratchpad
        for ( i = 0; i < 9; i++) {           // we need 9 bytes
          data[i] = ds.read();
        int16_t raw = (data[1] << 8) | data[0];
        if (type_s) {
          raw = raw << 3; // 9 bit resolution default
          if (data[7] == 0x10) {
            raw = (raw & 0xFFF0) + 12 - data[6];
        else {
          byte cfg = (data[4] & 0x60);
          if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
          else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
          else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
    celsius = (float)raw / 16.0;
    fahrenheit[x] = celsius * 1.8 + 32.0;
    Serial.println(fahrenheit[x]);
    Serial.println(x);
  float Avg_S_T =  (fahrenheit[0]+fahrenheit[1]+fahrenheit[2]+fahrenheit[3]+fahrenheit[4])/5.0;
  Serial.print("Average Soil Temperature: ");
  Serial.println(Avg_S_T);
SoilTemp();
delay(5000);
I have a for loop
You have more than one. Which one is causing you grief?
I don't think that is a reasonable hope.
PaulS:
The outermost one. Everything inside is taken from the oneWire example and is working fine. I just want to loop through this code 5 times to get five readings.
PaulS:
I don’t think that is a reasonable hope.
the only reason I say this bit about the five seconds is because I call
SoilTemp();
delay(5000);
SoilTemp() every 5 seconds. What I am saying I would like to wait a while then enter the SoilTemp() loop and get these five readings and then go back to the void loop and do what I want with it for another five seconds.
Here is another example where I did this. I want this code to be similar in functionality but with this different sensor.
#include <Wire.h>
int t,l,x;
float Avg_A_T = 0;
float TempArray[5];
Wire.begin();
Serial.println("Begin");
void AirTemp(){
  Avg_A_T = 0;
  for(x = 0; x < 5; x++)
    Wire.requestFrom(0x4F, 2);
    while(Wire.available())
    int8_t msb = Wire.read();
    int8_t lsb = Wire.read();
    // strip one bit of the lsb
    lsb = (lsb & 0x80 ) >> 7; // now lsb = 0 or 1
    // add to to form an float
    float T_C_A = msb + 0.5 * lsb;
    float T_F_A=(9.0/5.0)*T_C_A+32.0;
    TempArray[x] = T_F_A;
    //Serial.print(TempArray[x]);
  Avg_A_T =  (TempArray[0]+TempArray[1]+TempArray[2]+TempArray[3]+TempArray[4])/5.0;
AirTemp();
Serial.print("Average Temp F: ");
Serial.println(Avg_A_T);
delay(5000);
I think you need to show us the serial output from the sketch.
Anonymous printing sucks.
Serial.print("fahrenheit[");
Serial.print(x);
Serial.print("] = ");
conveys a lot more information than what you are printing.
PaulS: I think you need to show us the serial output from the sketch.
Serial.print(x);
Here you go. It is taking 5 seconds between each print so I believe that it is returning to the void loop between each printing instead of cycling through the outermost for loop.
fahrenheit[0] = 73.62
What does the fact that the index (X) in
is always 0 suggest to you?
econjack:
It suggests that the for loop is being exited after only running through once. Is of the return statements that is kicking me out of the for loop?
https://www.arduino.cc/en/Reference/Return
How about adding
Serial.println(func);
into beginning of each function? Into loop() , AirTemp etc.
Should lead you to the problem.
By itself there is nothing to stop loop() to continue forever - so the spec "run 5 times " must be specified elsewhere else.
here
AirTemp(); Serial.print("Average Temp F: "); Serial.println(Avg_A_T); delay(5000); }
I was able to get this to work by changing the location of the for loop. Here is a copy of my working code for closure.
int x =0;
float fahrenheit[5], Avg_S_Temp;
void setup(void) {
void SoilTemp(){
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheit[5];
    ds.reset_search();
    delay(250);
    return;
  for(int x = 0; x<5; x++){
  ds.reset();
  ds.select(addr);
  delay(500);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  ds.select(addr);
  if (type_s) {
  Serial.print(fahrenheit[x]);
  Serial.println(" Fahrenheit");
  Avg_S_Temp = (fahrenheit[0]+fahrenheit[1]+fahrenheit[2]+fahrenheit[3]+fahrenheit[4])/5.0;
  ds.reset_search();
SoilTemp();
Serial.println(Avg_S_Temp);
delay(5000);
The issue was that ds.search was returning 0 and returning early.
