Hello,
I'm having an issue with my current project. I want to calculate a crc from a string and want to do it in a dedicated function.
However I'm having a strange issue, maybe due to the compiler : if a display the value of i in a Serial.print(), the code does as it should. If i remove it, the result seems to be random...
the function is the following:
int calculateCrc(char* strtocalc, int size_str){
noInterrupts();
int byte_sum = 0;
for (int i=0; i< size_str; i++) {
int s = strtocalc[i];
byte_sum += s;
// Serial.print("i =");
// Serial.print(i);
Serial.print("end of loop, result=");
Serial.print(byte_sum);
interrupts();
return byte_sum;
the two commented line change the output : uncommenting them gives the expected result.
I taught some interrupt caused the issue, hence the stopinterrupts(), but it doesn't change anything.
I also tested to enter a manual string instead of a constructed one as an argument into the function : the problem doesn't append in this case... however when i print this constructed string before passing it as an argument: it is always the same one.
here is the function call with all the related code:
void sendToTecon()
char temperature_setpoint_1[8];
char temperature2_setpoint[8];
char reg_start[8];
sprintf(temperature2_setpoint,"%08x",(int)(tecon_setpoint_temperature2 * 10) );
sprintf(temperature_setpoint_1,"%08x",(int)(tecon_setpoint_temperature1 * 10) );
sprintf(reg_start,"%02x",(int)(tecon_reg_start) );
char tecon_req[39];
strcpy(tecon_req,"#0500C00");
strcat(tecon_req,temperature_setpoint_1);
strcat(tecon_req,temperature2_setpoint);
strcat(tecon_req,"01");
strcat(tecon_req,reg_start);
strcat(tecon_req,"********");
Serial.println(tecon_req);
// calculateCrc("#0500C00000000c8000000d2000000c80101********",36); this works.....
calculateCrc(tecon_req,36);
I'm really puzzled by this issue...
