Hi everyone.well I am very new to world of arduino.So hoping good solution for my problem
I am trying to work on water level sensing system using arduino with ping sensor sensor hc sr04.In my program I want to measure water level after every 4 mins with around 20 sets of level readings at the end of every 4 min with delay of 3secs.for this I inserted the for loop which seems to be ok but unable to produce any output on screen.while the system is working fine and giving out without FOR loop for particular time delay.
please suggest me for any error in my program or any other alternative method to work out for my code.
Here is my code
#include <NewPing.h>
#define TRIGGER_PIN 3
#define ECHO_PIN 2
#define MAX_DISTANCE 300
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
int level=0;
Serial.println("CLEARDATA");
Serial.println ("LABEL,Time,level");
delay(240000);
for ( int n=0;n>=20;n++){
int uS = sonar.ping();
level = uS / US_ROUNDTRIP_CM;
Serial.print("DATA,TIME,");
Serial.print (level);
Serial.println(" , ");
delay (3000);
