Hi everybody, I have a little problem about “for loop” on my main program.
char code;
while(Serial.available() <= 21){};
for(int i = 0; i < 22; i++)
code = Serial.read();
Serial.print(code);
Serial.print(code);
delay(2000);
Serial.flush();
I cant read the variable “code” outside of the “for loop”, i can only read her value on the loop
system
May 31, 2016, 2:19pm
#2
You change the value stored in the one variable 21 times. Only the last value will be available outside of the for loop.
Oh, ok
So how can i store these values on array and then read it outside the "for loop"
system
May 31, 2016, 4:52pm
#4
You store them IN an array. They fall off if you try to store them ON an array.
char myArray[30];
myArray[i] = Serial.read();
Serial.print(myArray[i]);
myArray[22] = '\0';
and then read it outside the “for loop”
Serial.print("myArray contains: [");
Serial.print(myArray);
Serial.println("]");
Ok thank you but the result of ur code its : myArray contains: [FF2E9E010B01010D125B08YóS]
thats good but there are “YóS” at the end and i wont it on my array !
my code :
char code[22];
while(Serial.available() <= 22){}
code[i] = Serial.read();
Serial.print(" myArray contains: [");
Serial.print(code);
Serial.flush();
Oh ok nothing thats right i read the good code of my badge
So now i want to compare the value of the array betwen a string like "FFFSSDSQDq444" so how can i do it ?
These are pretty basic questions. You need to start researching this stuff yourself. Googling "compare C strings" got me 44.8 million hits. I'll bet one of those will likely help you answer your own question.
